Date/Time: Fri, 31 Jan 2025 11:51:18 +0000
1 Window is not in place
View Count: 618
[2019-05-03 16:07:09] |
User97684 - Posts: 136 |
Hi, PLs could you help me - every time i switch betweeen chart books, one of my winodws is not in its place in my 6E chart book - window / chart # 4. Pls see attached Many thanks |
window_missing_1.png / V - Attached On 2019-05-03 16:06:41 UTC - Size: 195.6 KB - 258 views missing_window_2.png / V - Attached On 2019-05-03 16:06:54 UTC - Size: 168.06 KB - 227 views |
[2019-05-03 19:26:40] |
You need to change the display order so it is above other windows. You can do that through Windows and Chartbooks window: Window, CB and CW Menus: Windows and Chartbooks (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-03 19:27:52
