Date/Time: Mon, 21 Sep 2026 03:37:13 +0000
ASCIL: sc.Bid, sc.Ask float is odd?
View Count: 1190
[2019-05-03 15:34:54]
TedMar - Posts: 191
on live CQG connection, when i output sc.Ask or sc.Bid without Flags to cut/cast float (%f) i get ASK/BID odd value like 57.629997
check pic.
whats wrong?, in fact i need sc.Ask/Bid the value for calculatios. Is posible get them without any casting?
image2019-05-03 13_21_17-Window.png / V - Attached On 2019-05-03 15:30:51 UTC - Size: 22.59 KB - 388 views
[2019-05-03 18:56:34]
Yes that does make sense what you see. You need to use %.2f in this case to round off the floating-point error.
[2019-05-03 19:14:36]
TedMar - Posts: 191
but symbols have diffrent Ticksize , i can not cut all with %.2f
i tryed
float rAsk = sc.RoundToTickSize(sc.Ask/sc.TickSize);
rAsk = rAsk * sc.TickSize;
but result is same as sc.Ask
any ideas?
[2019-05-03 19:20:55]
Therefore, use this function:
ACSIL Interface Members - Functions: sc.FormatGraphValue()
Date Time Of Last Edit: 2019-05-03 19:21:02
[2019-05-03 19:27:18]
TedMar - Posts: 191
unposible, i have not chart open
i use s_SCBasicSymbolData with sc.GetBasicSymbolData
any other idea?
