Date/Time: Fri, 31 Jan 2025 10:43:54 +0000
Numbers bars coloring based on relative volume
View Count: 803
[2019-05-03 15:23:17]
LEtrading - Posts: 4
I was wondering if there is a option to set up te coloring of the Numbers bars based on the relative bid/ask volume to all visible bars?
Using the numbers bars settings 'based on bid/ask percentage' and 'based on dominant bid/ask actual don't show the relative change clearly.
Looking forward to your response
[2019-05-03 18:55:44]
No, this is not supported but the volume bars for each displayed column can be set to be relative to all visible bars.
[2019-05-03 20:21:55]
Yes i know. And i've used this setting but i find it visually more pleasing to use the full background.
Would you be willing to add this feature?
[2019-05-06 20:41:33]
We will have to see about this.
