Date/Time: Fri, 31 Jan 2025 11:48:55 +0000
Linking Charts to Automatically Keep Different Time Ratios
View Count: 984
[2019-05-03 13:20:32] |
absorrel4 - Posts: 97 |
I know how to link charts so that if I change the timeframe on one chart it is automatically changed on the other chart. If I have two or more charts with different timeframes (e.g., 1 minute on one chart and 3 minute a different chart....a 1:3 ratio) can I link them so that the ratio difference is maintained. If I change the 1 minute chart to 5 minutes, the second chart is automatically changed to 15 minutes to maintain the 1:3 ratio? I understand that this did not seem possible in earlier SC versions....is it possible now? Could this be accomplished via a custom study linking the two charts? |
[2019-05-03 19:14:06] |
This is not supported. Not sure how this would be done through ACSIL either.
