Date/Time: Fri, 31 Jan 2025 10:54:29 +0000
Trailing Entry + Moving Average
View Count: 957
[2019-05-03 08:40:05] |
User447246 - Posts: 7 |
Hi, i would like to trail the order entry along the moving average (EMA) with a limit order until the price touches the moving average (EMA)and the order will be filled. How to do? Thanks in advance for your kind help ... Thomas |
trailing order entry.jpg / V - Attached On 2019-05-03 08:27:37 UTC - Size: 51.49 KB - 309 views Attachment Deleted. |
[2019-05-05 17:46:55] |
Have a look at using this particular study: Attached Orders: Study Controlled Targets and Stops Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
