Date/Time: Fri, 31 Jan 2025 12:44:40 +0000
can I clear current traded bid/ask volume from ASCIL study?
View Count: 1177
[2019-05-03 03:30:23]
User153286 - Posts: 49
I have current bid combined and ask traded volume displayed in the chart dom and I can manually clear them using a keyboard short cut I created.
1.) Is there a way I can clear them from an ASCIL study?
2.) Or is there a way to limit the the current bid, combined and ask data to some number of bars... for example only use the last 5 bars of data to create the total amounts displayed?
[2019-05-03 19:09:30]
1. Yes, use this function:
sc.ClearCurrentTradedBidAskVolume()
Although this function only exists in version 1916 and higher. This will be out in about 20 minutes.
2. No.
Date Time Of Last Edit: 2019-05-03 19:11:49
[2019-05-10 04:14:40]
when will version 1916 be available for download? I just tried to update but can only get 1915
[2019-05-10 14:47:39]
John - SC Support - Posts: 37621
Version 1917 is currently available as the Pre-Release. The Current Version is still 1915. So if you want to get these changes, you need to update to the latest Pre-Release version. Refer to the following to perform a Fast Update:
