Date/Time: Fri, 31 Jan 2025 11:50:07 +0000
datafeed Rithmic trading with TopStep Trader
View Count: 1462
[2019-05-03 01:41:10] |
User851645 - Posts: 2 |
I'm trying to log in with datafeed Rithmic trading with TopStep Trader but I can't. With Rithmic's R-Trader, everything is ok, I sent the message log Reading Internal Order ID file. | 2019-05-02 18:29:18 Reading Trade Orders file. | 2019-05-02 18:29:18 Reading Trade Positions file. | 2019-05-02 18:29:18 Reading Account Balance file. | 2019-05-02 18:29:18 UDPListener (1404). Port 22903 | Listening on UDP port 22903. | 2019-05-02 18:29:18 Software version: 1898 32-bit | 2019-05-02 18:29:18 Usage end date: 2019-05-18 | 2019-05-02 18:29:18 Enabled for: Advanced Features. | 2019-05-02 18:29:18 Enabled for: Advanced Features 2. | 2019-05-02 18:29:18 Enabled for: Sierra Chart Historical Data Service. | 2019-05-02 18:29:18 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-05-02 18:29:18 Current selected Data/Trading service: Rithmic Trading | 2019-05-02 18:29:18 Chart Update Interval: 10 | 2019-05-02 18:29:18 Intraday Data Storage Time Unit: 0 | 2019-05-02 18:29:18 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-05-02 18:29:18 2019-05-03 01:29:18 Local computer time | 2019-05-02 18:29:18 2019-05-02 23:29:18 Local computer time in UTC | 2019-05-02 18:29:18 2019-05-02 18:29:18 Local computer time in SC Time Zone | 2019-05-02 18:29:18 2019-05-02 23:29:16 Server time in UTC | 2019-05-02 18:29:18 Local computer UTC time and Server UTC time difference: 2 seconds. | 2019-05-02 18:29:18 Program path: C:\SierraChart\ | 2019-05-02 18:29:18 Data Files path: C:\SierraChart\Data\ | 2019-05-02 18:29:18 OS Version Number: 10.0 | 2019-05-02 18:29:18 Locale Setting: C | 2019-05-02 18:29:18 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-05-02 18:29:18 Created the DTC Protocol server. | 2019-05-02 18:29:18 DTC Protocol Server listening on port 11099. | 2019-05-02 18:29:18 Created the DTC Protocol historical data server. | 2019-05-02 18:29:18 HD Server Manager | Listening on port 11098 | 2019-05-02 18:29:18 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2019-05-02 18:29:18 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-05-02 18:29:18 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-05-02 18:29:18 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-05-02 18:29:18 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-05-02 18:29:18 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-05-02 18:29:18 Received 5 login tokens. | 2019-05-02 18:29:19 Symbol settings MD5 received. Request ID: 1. | 2019-05-02 18:29:19 Symbol settings are up-to-date for rithmic.trading. | 2019-05-02 18:29:19 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-05-02 18:29:19 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-05-02 18:29:19 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-05-02 18:29:19 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-05-02 18:29:19 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-05-02 18:29:19 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-05-02 18:29:19 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-05-02 18:29:20 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-05-02 18:29:20 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-05-02 18:29:21 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-05-02 18:29:21 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-05-02 18:29:21 Files to Open on Start up | Opening file: DOM-Market Depth.Cht | 2019-05-02 18:29:22 NQM19 0.50 Range #2 | Reloading chart. | 2019-05-02 18:29:22 NQM19 1 Min #6 | Reloading chart. | 2019-05-02 18:29:22 nqM19 Renko 4t #7 | Reloading chart. | 2019-05-02 18:29:22 ESM19 0.25 Range #1 | Reloading chart. | 2019-05-02 18:29:22 nqM19 #4 | Reloading chart. | 2019-05-02 18:29:22 nqM19 #4 | StartDateTimeForLoadingOrderFills: 2019-04-30 15:59:59 | 2019-05-02 18:29:23 + Loading market depth data. | 2019-05-02 18:29:23 Loaded depth data records for ESM19 2019-04-30 from 2019-04-30 16:42:10 to 2019-04-30 18:59:59. | 2019-05-02 18:29:23 Loaded depth data records for ESM19 2019-05-01 from 2019-04-30 19:00:00 to 2019-05-01 18:59:59. | 2019-05-02 18:29:23 Loaded depth data records for ESM19 2019-05-02 from 2019-05-01 19:00:01 to 2019-05-02 15:40:24. | 2019-05-02 18:29:23 ESM19 0.25 Range #1 | Reloading chart. | 2019-05-02 18:29:23 nqM19 Renko 4t #7 | StartDateTimeForLoadingOrderFills: 2019-04-29 17:00:00 | 2019-05-02 18:29:23 + Loading market depth data. | 2019-05-02 18:29:24 Loaded depth data records for ESM19 2019-04-30 from 2019-04-30 16:42:10 to 2019-04-30 18:59:59. | 2019-05-02 18:29:24 Rithmic Trading | Port for executable: 58270 | 2019-05-02 18:29:24 Listening socket (1508). Port 58270 | Closed. | 2019-05-02 18:29:24 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 18:29:24 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58270. Current folder: C:\SierraChart\Rim | 2019-05-02 18:29:24 Loaded depth data records for ESM19 2019-05-01 from 2019-04-30 19:00:00 to 2019-05-01 18:59:59. | 2019-05-02 18:29:24 Loaded depth data records for ESM19 2019-05-02 from 2019-05-01 19:00:01 to 2019-05-02 15:40:24. | 2019-05-02 18:29:24 + Loading market depth data. | 2019-05-02 18:29:25 Loaded depth data records for NQM19 2019-04-22 from 00:00:00 to 00:00:00. | 2019-05-02 18:29:25 Loaded depth data records for NQM19 2019-04-23 from 2019-04-23 08:18:25 to 2019-04-23 17:27:03. | 2019-05-02 18:29:25 Loaded depth data records for NQM19 2019-04-24 from 2019-04-24 04:11:12 to 2019-04-24 15:52:26. | 2019-05-02 18:29:26 Loaded depth data records for NQM19 2019-04-25 from 2019-04-25 07:15:10 to 2019-04-25 17:20:26. | 2019-05-02 18:29:26 Loaded depth data records for NQM19 2019-04-26 from 2019-04-26 04:44:24 to 2019-04-26 10:33:23. | 2019-05-02 18:29:26 Loaded depth data records for NQM19 2019-04-28 from 2019-04-28 17:45:37 to 2019-04-28 18:01:12. | 2019-05-02 18:29:26 Loaded depth data records for NQM19 2019-04-29 from 2019-04-29 05:36:48 to 2019-04-29 18:06:57. | 2019-05-02 18:29:26 Loaded depth data records for NQM19 2019-04-30 from 2019-04-30 03:23:18 to 2019-04-30 18:59:59. | 2019-05-02 18:29:26 Rithmic Trading | Bridge process is running. | 2019-05-02 18:29:26 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58270 | 2019-05-02 18:29:26 DTC Client socket (1) | Creating socket. | 2019-05-02 18:29:26 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 18:29:26 Rithmic Trading | Connected to server. | 2019-05-02 18:29:26 Rithmic Trading | Starting socket receive thread. | 2019-05-02 18:29:26 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-05-02 18:29:26 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-05-02 18:29:26 Rithmic Trading | Sending logon request message. | 2019-05-02 18:29:26 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-05-02 18:29:26 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-05-02 18:29:26 Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2019-05-02 18:29:26 Loaded depth data records for NQM19 2019-05-01 from 2019-04-30 19:00:01 to 2019-05-01 18:59:59. | 2019-05-02 18:29:26 Loaded depth data records for NQM19 2019-05-02 from 2019-05-01 19:00:00 to 2019-05-02 15:40:23. | 2019-05-02 18:29:26 NQM19 0.50 Range #2 | StartDateTimeForLoadingOrderFills: 2019-04-14 17:00:00 | 2019-05-02 18:29:26 NQM19 1 Min #6 | StartDateTimeForLoadingOrderFills: 2019-03-03 17:00:00 | 2019-05-02 18:29:30 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-05-02 18:29:30 DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 129 | 2019-05-02 18:29:31 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-05-02 18:29:31 Rithmic Trading | Received logon response. | 2019-05-02 18:29:31 Rithmic Trading | Server Name: DTC Bridge. | 2019-05-02 18:29:31 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-05-02 18:29:31 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-05-02 18:29:31 DTC Client socket (1) | Closed. | 2019-05-02 18:29:31 Rithmic Trading | Logon error received from server | 2019-05-02 18:29:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 18:29:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:29:31 Rithmic Trading | Disconnected. | 2019-05-02 18:29:31 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:29:31 Rithmic Trading | Port for executable: 58306 | 2019-05-02 18:29:33 Listening socket (1528). Port 58306 | Closed. | 2019-05-02 18:29:33 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 18:29:33 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58306. Current folder: C:\SierraChart\Rim | 2019-05-02 18:29:33 Rithmic Trading | Bridge process is not running! | 2019-05-02 18:29:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58306 | 2019-05-02 18:29:35 DTC Client socket (1) | Creating socket. | 2019-05-02 18:29:35 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 18:29:35 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 18:29:36 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 18:29:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:29:36 DTC Client socket (1) | Closed. | 2019-05-02 18:29:36 Rithmic Trading | Disconnected. | 2019-05-02 18:29:36 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:29:36 Rithmic Trading | Port for executable: 58323 | 2019-05-02 18:29:38 Listening socket (1436). Port 58323 | Closed. | 2019-05-02 18:29:38 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 18:29:38 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58323. Current folder: C:\SierraChart\Rim | 2019-05-02 18:29:38 Rithmic Trading | Bridge process is not running! | 2019-05-02 18:29:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58323 | 2019-05-02 18:29:40 DTC Client socket (1) | Creating socket. | 2019-05-02 18:29:40 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 18:29:40 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 18:29:41 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 18:29:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:29:41 DTC Client socket (1) | Closed. | 2019-05-02 18:29:41 Rithmic Trading | Disconnected. | 2019-05-02 18:29:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:29:41 Rithmic Trading | Port for executable: 58341 | 2019-05-02 18:29:43 Listening socket (1500). Port 58341 | Closed. | 2019-05-02 18:29:43 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 18:29:43 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58341. Current folder: C:\SierraChart\Rim | 2019-05-02 18:29:43 File >> Disconnect selected. | 2019-05-02 18:29:44 Rithmic Trading | Disconnected. | 2019-05-02 18:29:44 Rithmic Trading | Port for executable: 58353 | 2019-05-02 18:29:47 Listening socket (1528). Port 58353 | Closed. | 2019-05-02 18:29:47 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 18:29:47 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58353. Current folder: C:\SierraChart\Rim | 2019-05-02 18:29:47 Rithmic Trading | Bridge process is not running! | 2019-05-02 18:29:49 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58353 | 2019-05-02 18:29:49 DTC Client socket (1) | Creating socket. | 2019-05-02 18:29:49 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 18:29:49 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 18:29:50 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 18:29:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:29:50 DTC Client socket (1) | Closed. | 2019-05-02 18:29:50 Rithmic Trading | Disconnected. | 2019-05-02 18:29:50 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:29:50 Rithmic Trading | Port for executable: 58371 | 2019-05-02 18:29:52 Listening socket (1500). Port 58371 | Closed. | 2019-05-02 18:29:52 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 18:29:52 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58371. Current folder: C:\SierraChart\Rim | 2019-05-02 18:29:52 Rithmic Trading | Bridge process is not running! | 2019-05-02 18:29:54 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58371 | 2019-05-02 18:29:54 DTC Client socket (1) | Creating socket. | 2019-05-02 18:29:54 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 18:29:54 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 18:29:55 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 18:29:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:29:55 DTC Client socket (1) | Closed. | 2019-05-02 18:29:55 Rithmic Trading | Disconnected. | 2019-05-02 18:29:55 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:29:55 Rithmic Trading | Port for executable: 58389 | 2019-05-02 18:29:57 Listening socket (1436). Port 58389 | Closed. | 2019-05-02 18:29:57 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 18:29:57 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58389. Current folder: C:\SierraChart\Rim | 2019-05-02 18:29:57 Rithmic Trading | Bridge process is running. | 2019-05-02 18:29:59 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58389 | 2019-05-02 18:29:59 DTC Client socket (1) | Creating socket. | 2019-05-02 18:29:59 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 18:29:59 Rithmic Trading | Connected to server. | 2019-05-02 18:29:59 Rithmic Trading | Starting socket receive thread. | 2019-05-02 18:29:59 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-05-02 18:29:59 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-05-02 18:29:59 Rithmic Trading | Sending logon request message. | 2019-05-02 18:29:59 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-05-02 18:29:59 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-05-02 18:29:59 Rithmic Trading | Message from server: Connecting to Rithmic Topstep Trader Europe server. | 2019-05-02 18:29:59 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-05-02 18:30:03 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-05-02 18:30:03 Rithmic Trading | Received logon response. | 2019-05-02 18:30:03 Rithmic Trading | Server Name: DTC Bridge. | 2019-05-02 18:30:03 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-05-02 18:30:03 Rithmic Trading | Logon error received from server | 2019-05-02 18:30:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 18:30:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:30:03 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-05-02 18:30:03 DTC Client socket (1) | Closed. | 2019-05-02 18:30:03 Rithmic Trading | Disconnected. | 2019-05-02 18:30:03 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:30:03 Rithmic Trading | Port for executable: 58420 | 2019-05-02 18:30:05 Listening socket (1480). Port 58420 | Closed. | 2019-05-02 18:30:05 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 18:30:05 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58420. Current folder: C:\SierraChart\Rim | 2019-05-02 18:30:05 Rithmic Trading | Bridge process is not running! | 2019-05-02 18:30:07 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58420 | 2019-05-02 18:30:07 DTC Client socket (1) | Creating socket. | 2019-05-02 18:30:07 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 18:30:07 File >> Disconnect selected. | 2019-05-02 18:30:08 Rithmic Trading | Disconnected. | 2019-05-02 18:30:08 DTC Client socket (1) | Closed. | 2019-05-02 18:30:08 NQM19 1 Min #6 | Reloading chart. | 2019-05-03 01:30:29 nqM19 Renko 4t #7 | Reloading chart. | 2019-05-03 01:30:29 ESM19 0.25 Range #1 | Reloading chart. | 2019-05-03 01:30:29 nqM19 #4 | Reloading chart. | 2019-05-03 01:30:29 NQM19 0.50 Range #2 | Reloading chart. | 2019-05-03 01:30:29 nqM19 #4 | StartDateTimeForLoadingOrderFills: 2019-04-30 16:15:00 | 2019-05-03 01:30:30 + Loading market depth data. | 2019-05-03 01:30:30 nqM19 Renko 4t #7 | StartDateTimeForLoadingOrderFills: 2019-04-29 17:00:00 | 2019-05-03 01:30:31 Loaded depth data records for ESM19 2019-04-30 from 2019-04-30 16:15:00 to 2019-05-01 01:59:59. | 2019-05-03 01:30:31 Loaded depth data records for ESM19 2019-05-01 from 2019-05-01 02:00:00 to 2019-05-02 01:59:59. | 2019-05-03 01:30:31 Loaded depth data records for ESM19 2019-05-02 from 2019-05-02 02:00:01 to 2019-05-02 22:40:24. | 2019-05-03 01:30:31 + Loading market depth data. | 2019-05-03 01:30:32 Loaded depth data records for NQM19 2019-04-22 from 00:00:00 to 00:00:00. | 2019-05-03 01:30:32 Loaded depth data records for NQM19 2019-04-23 from 2019-04-23 15:18:25 to 2019-04-24 00:27:03. | 2019-05-03 01:30:32 Loaded depth data records for NQM19 2019-04-24 from 2019-04-24 11:11:12 to 2019-04-24 22:52:26. | 2019-05-03 01:30:32 Loaded depth data records for NQM19 2019-04-25 from 2019-04-25 14:15:10 to 2019-04-26 00:20:26. | 2019-05-03 01:30:32 Loaded depth data records for NQM19 2019-04-26 from 2019-04-26 11:44:24 to 2019-04-26 17:33:23. | 2019-05-03 01:30:33 Loaded depth data records for NQM19 2019-04-28 from 2019-04-29 00:45:37 to 2019-04-29 01:01:12. | 2019-05-03 01:30:33 Loaded depth data records for NQM19 2019-04-29 from 2019-04-29 12:36:48 to 2019-04-30 01:06:57. | 2019-05-03 01:30:33 Loaded depth data records for NQM19 2019-04-30 from 2019-04-30 10:23:18 to 2019-05-01 01:59:59. | 2019-05-03 01:30:33 Loaded depth data records for NQM19 2019-05-01 from 2019-05-01 02:00:01 to 2019-05-02 01:59:59. | 2019-05-03 01:30:33 Rithmic Trading | Port for executable: 58453 | 2019-05-03 01:30:33 Listening socket (1544). Port 58453 | Closed. | 2019-05-03 01:30:33 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-03 01:30:33 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58453. Current folder: C:\SierraChart\Rim | 2019-05-03 01:30:33 Loaded depth data records for NQM19 2019-05-02 from 2019-05-02 02:00:00 to 2019-05-02 22:40:23. | 2019-05-03 01:30:33 NQM19 0.50 Range #2 | StartDateTimeForLoadingOrderFills: 2019-04-12 17:00:00 | 2019-05-03 01:30:33 Rithmic Trading | Bridge process is running. | 2019-05-03 01:30:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58453 | 2019-05-03 01:30:35 DTC Client socket (1) | Creating socket. | 2019-05-03 01:30:35 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-03 01:30:35 Rithmic Trading | Connected to server. | 2019-05-03 01:30:35 Rithmic Trading | Starting socket receive thread. | 2019-05-03 01:30:35 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-05-03 01:30:35 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-05-03 01:30:35 Rithmic Trading | Sending logon request message. | 2019-05-03 01:30:35 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-05-03 01:30:35 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-05-03 01:30:35 Rithmic Trading | Message from server: Connecting to Rithmic Topstep Trader Europe server. | 2019-05-03 01:30:35 NQM19 1 Min #6 | StartDateTimeForLoadingOrderFills: 2019-03-04 00:00:00 | 2019-05-03 01:30:36 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-05-03 01:30:38 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-05-03 01:30:38 Rithmic Trading | Received logon response. | 2019-05-03 01:30:38 Rithmic Trading | Server Name: DTC Bridge. | 2019-05-03 01:30:38 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-05-03 01:30:38 Rithmic Trading | Logon error received from server | 2019-05-03 01:30:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-03 01:30:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-03 01:30:38 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-05-03 01:30:38 DTC Client socket (1) | Closed. | 2019-05-03 01:30:38 Rithmic Trading | Disconnected. | 2019-05-03 01:30:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-03 01:30:38 Rithmic Trading | Port for executable: 58470 | 2019-05-03 01:30:40 Listening socket (1560). Port 58470 | Closed. | 2019-05-03 01:30:40 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-03 01:30:40 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58470. Current folder: C:\SierraChart\Rim | 2019-05-03 01:30:40 File >> Disconnect selected. | 2019-05-03 01:30:41 Rithmic Trading | Disconnected. | 2019-05-03 01:30:41 NQM19 0.50 Range #2 | Reloading chart. | 2019-05-02 18:31:20 nqM19 #4 | Reloading chart. | 2019-05-02 18:31:20 ESM19 0.25 Range #1 | Reloading chart. | 2019-05-02 18:31:20 nqM19 Renko 4t #7 | Reloading chart. | 2019-05-02 18:31:20 NQM19 1 Min #6 | Reloading chart. | 2019-05-02 18:31:20 nqM19 #4 | StartDateTimeForLoadingOrderFills: 2019-04-30 15:59:59 | 2019-05-02 18:31:20 + Loading market depth data. | 2019-05-02 18:31:21 Loaded depth data records for ESM19 2019-04-30 from 2019-04-30 16:42:10 to 2019-04-30 18:59:59. | 2019-05-02 18:31:21 Loaded depth data records for ESM19 2019-05-01 from 2019-04-30 19:00:00 to 2019-05-01 18:59:59. | 2019-05-02 18:31:21 Loaded depth data records for ESM19 2019-05-02 from 2019-05-01 19:00:01 to 2019-05-02 15:40:24. | 2019-05-02 18:31:21 nqM19 Renko 4t #7 | StartDateTimeForLoadingOrderFills: 2019-04-29 17:00:00 | 2019-05-02 18:31:21 + Loading market depth data. | 2019-05-02 18:31:23 Loaded depth data records for NQM19 2019-04-22 from 00:00:00 to 00:00:00. | 2019-05-02 18:31:23 Loaded depth data records for NQM19 2019-04-23 from 2019-04-23 08:18:25 to 2019-04-23 17:27:03. | 2019-05-02 18:31:23 Loaded depth data records for NQM19 2019-04-24 from 2019-04-24 04:11:12 to 2019-04-24 15:52:26. | 2019-05-02 18:31:23 Loaded depth data records for NQM19 2019-04-25 from 2019-04-25 07:15:10 to 2019-04-25 17:20:26. | 2019-05-02 18:31:23 Loaded depth data records for NQM19 2019-04-26 from 2019-04-26 04:44:24 to 2019-04-26 10:33:23. | 2019-05-02 18:31:23 Loaded depth data records for NQM19 2019-04-28 from 2019-04-28 17:45:37 to 2019-04-28 18:01:12. | 2019-05-02 18:31:23 Loaded depth data records for NQM19 2019-04-29 from 2019-04-29 05:36:48 to 2019-04-29 18:06:57. | 2019-05-02 18:31:23 Loaded depth data records for NQM19 2019-04-30 from 2019-04-30 03:23:18 to 2019-04-30 18:59:59. | 2019-05-02 18:31:24 Loaded depth data records for NQM19 2019-05-01 from 2019-04-30 19:00:01 to 2019-05-01 18:59:59. | 2019-05-02 18:31:24 Loaded depth data records for NQM19 2019-05-02 from 2019-05-01 19:00:00 to 2019-05-02 15:40:23. | 2019-05-02 18:31:24 NQM19 0.50 Range #2 | StartDateTimeForLoadingOrderFills: 2019-04-14 17:00:00 | 2019-05-02 18:31:24 Rithmic Trading | Port for executable: 58519 | 2019-05-02 18:31:24 Listening socket (1588). Port 58519 | Closed. | 2019-05-02 18:31:24 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 18:31:24 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58519. Current folder: C:\SierraChart\Rim | 2019-05-02 18:31:24 Rithmic Trading | Bridge process is running. | 2019-05-02 18:31:26 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58519 | 2019-05-02 18:31:26 DTC Client socket (1) | Creating socket. | 2019-05-02 18:31:26 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 18:31:26 Rithmic Trading | Connected to server. | 2019-05-02 18:31:26 Rithmic Trading | Starting socket receive thread. | 2019-05-02 18:31:26 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-05-02 18:31:26 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-05-02 18:31:26 Rithmic Trading | Sending logon request message. | 2019-05-02 18:31:26 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-05-02 18:31:26 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-05-02 18:31:26 Rithmic Trading | Message from server: Connecting to Rithmic Topstep Trader server. | 2019-05-02 18:31:26 NQM19 1 Min #6 | StartDateTimeForLoadingOrderFills: 2019-03-03 17:00:00 | 2019-05-02 18:31:27 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-05-02 18:31:30 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-05-02 18:31:30 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-05-02 18:31:30 DTC Client socket (1) | Closed. | 2019-05-02 18:31:30 Rithmic Trading | Received logon response. | 2019-05-02 18:31:30 Rithmic Trading | Server Name: DTC Bridge. | 2019-05-02 18:31:30 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-05-02 18:31:30 Rithmic Trading | Logon error received from server | 2019-05-02 18:31:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 18:31:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:31:30 Rithmic Trading | Disconnected. | 2019-05-02 18:31:30 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 18:31:30 Rithmic Trading | Port for executable: 58536 | 2019-05-02 18:31:32 Listening socket (1636). Port 58536 | Closed. | 2019-05-02 18:31:32 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 18:31:32 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58536. Current folder: C:\SierraChart\Rim | 2019-05-02 18:31:32 File >> Disconnect selected. | 2019-05-02 18:31:33 Rithmic Trading | Disconnected. | 2019-05-02 18:31:33 ESM19 1 Day #2 | Reloading chart. | 2019-05-02 18:37:54 ESm19 Renko 4t #4 | Reloading chart. | 2019-05-02 18:37:54 ESm19 Renko 2t #1 | Reloading chart. | 2019-05-02 18:37:54 ESM19 1.75 Range #3 | Reloading chart. | 2019-05-02 18:37:54 ESM19 0.25 Range #5 | Reloading chart. | 2019-05-02 18:37:54 + Loading market depth data. | 2019-05-02 18:37:55 Loaded depth data records for ESM19 2019-04-30 from 2019-04-30 16:42:10 to 2019-04-30 18:59:59. | 2019-05-02 18:37:55 Loaded depth data records for ESM19 2019-05-01 from 2019-04-30 19:00:00 to 2019-05-01 18:59:59. | 2019-05-02 18:37:55 Loaded depth data records for ESM19 2019-05-02 from 2019-05-01 19:00:01 to 2019-05-02 15:40:24. | 2019-05-02 18:37:55 ESM19 0.25 Range #5 | StartDateTimeForLoadingOrderFills: 2019-04-30 15:59:59 | 2019-05-02 18:37:55 ESM19 0.25 Range #5 | Reloading chart. | 2019-05-02 18:37:55 + Loading market depth data. | 2019-05-02 18:37:56 Loaded depth data records for ESM19 2019-04-30 from 2019-04-30 16:42:10 to 2019-04-30 18:59:59. | 2019-05-02 18:37:56 Loaded depth data records for ESM19 2019-05-01 from 2019-04-30 19:00:00 to 2019-05-01 18:59:59. | 2019-05-02 18:37:57 Loaded depth data records for ESM19 2019-05-02 from 2019-05-01 19:00:01 to 2019-05-02 15:40:24. | 2019-05-02 18:37:57 ESM19 0.25 Range #5 | StartDateTimeForLoadingOrderFills: 2019-04-30 15:59:59 | 2019-05-02 18:37:57 ESM19 1.75 Range #3 | StartDateTimeForLoadingOrderFills: 2019-04-02 17:00:00 | 2019-05-02 18:38:02 ESm19 Renko 4t #4 | StartDateTimeForLoadingOrderFills: 2019-03-03 17:00:00 | 2019-05-02 18:38:10 ESm19 Renko 2t #1 | StartDateTimeForLoadingOrderFills: 2019-03-03 17:00:00 | 2019-05-02 18:38:10 Rithmic Trading | Port for executable: 60536 | 2019-05-02 19:01:43 Listening socket (1744). Port 60536 | Closed. | 2019-05-02 19:01:43 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 19:01:43 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:60536. Current folder: C:\SierraChart\Rim | 2019-05-02 19:01:43 Rithmic Trading | Bridge process is running. | 2019-05-02 19:01:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60536 | 2019-05-02 19:01:45 DTC Client socket (1) | Creating socket. | 2019-05-02 19:01:45 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 19:01:45 Rithmic Trading | Connected to server. | 2019-05-02 19:01:45 Rithmic Trading | Starting socket receive thread. | 2019-05-02 19:01:45 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-05-02 19:01:45 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-05-02 19:01:45 Rithmic Trading | Sending logon request message. | 2019-05-02 19:01:45 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-05-02 19:01:45 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-05-02 19:01:45 Rithmic Trading | Message from server: Connecting to Rithmic Topstep Trader server. | 2019-05-02 19:01:45 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-05-02 19:01:49 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-05-02 19:01:49 Rithmic Trading | Received logon response. | 2019-05-02 19:01:49 Rithmic Trading | Server Name: DTC Bridge. | 2019-05-02 19:01:49 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-05-02 19:01:49 Rithmic Trading | Logon error received from server | 2019-05-02 19:01:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 19:01:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:01:49 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-05-02 19:01:49 DTC Client socket (1) | Closed. | 2019-05-02 19:01:49 Rithmic Trading | Disconnected. | 2019-05-02 19:01:49 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:01:49 Rithmic Trading | Port for executable: 60557 | 2019-05-02 19:01:51 Listening socket (1868). Port 60557 | Closed. | 2019-05-02 19:01:51 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 19:01:51 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:60557. Current folder: C:\SierraChart\Rim | 2019-05-02 19:01:51 Rithmic Trading | Bridge process is not running! | 2019-05-02 19:01:53 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60557 | 2019-05-02 19:01:53 DTC Client socket (1) | Creating socket. | 2019-05-02 19:01:53 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 19:01:53 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 19:01:54 * DTC Client socket (1) | Closed. | 2019-05-02 19:01:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 19:01:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:01:54 Rithmic Trading | Disconnected. | 2019-05-02 19:01:54 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:01:54 Rithmic Trading | Port for executable: 60565 | 2019-05-02 19:01:56 Listening socket (1956). Port 60565 | Closed. | 2019-05-02 19:01:56 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 19:01:56 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:60565. Current folder: C:\SierraChart\Rim | 2019-05-02 19:01:56 Rithmic Trading | Bridge process is not running! | 2019-05-02 19:01:58 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60565 | 2019-05-02 19:01:58 DTC Client socket (1) | Creating socket. | 2019-05-02 19:01:58 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 19:01:58 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 19:01:59 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 19:01:59 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:01:59 DTC Client socket (1) | Closed. | 2019-05-02 19:01:59 Rithmic Trading | Disconnected. | 2019-05-02 19:01:59 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:01:59 File >> Disconnect selected. | 2019-05-02 19:02:00 Rithmic Trading | Disconnected. | 2019-05-02 19:02:00 Rithmic Trading | Port for executable: 60988 | 2019-05-02 19:08:02 Listening socket (1776). Port 60988 | Closed. | 2019-05-02 19:08:02 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 19:08:02 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:60988. Current folder: C:\SierraChart\Rim | 2019-05-02 19:08:02 Rithmic Trading | Bridge process is running. | 2019-05-02 19:08:04 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60988 | 2019-05-02 19:08:04 DTC Client socket (1) | Creating socket. | 2019-05-02 19:08:04 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 19:08:04 Rithmic Trading | Connected to server. | 2019-05-02 19:08:04 Rithmic Trading | Starting socket receive thread. | 2019-05-02 19:08:04 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-05-02 19:08:04 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-05-02 19:08:04 Rithmic Trading | Sending logon request message. | 2019-05-02 19:08:04 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-05-02 19:08:04 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-05-02 19:08:04 Rithmic Trading | Message from server: Connecting to Rithmic Topstep Trader server. | 2019-05-02 19:08:04 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-05-02 19:08:08 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-05-02 19:08:08 Rithmic Trading | Received logon response. | 2019-05-02 19:08:08 Rithmic Trading | Server Name: DTC Bridge. | 2019-05-02 19:08:08 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-05-02 19:08:08 Rithmic Trading | Logon error received from server | 2019-05-02 19:08:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 19:08:08 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:08:08 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-05-02 19:08:08 DTC Client socket (1) | Closed. | 2019-05-02 19:08:08 Rithmic Trading | Disconnected. | 2019-05-02 19:08:08 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:08:08 Rithmic Trading | Port for executable: 61006 | 2019-05-02 19:08:10 Listening socket (1776). Port 61006 | Closed. | 2019-05-02 19:08:10 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 19:08:10 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:61006. Current folder: C:\SierraChart\Rim | 2019-05-02 19:08:10 Rithmic Trading | Bridge process is not running! | 2019-05-02 19:08:12 Rithmic Trading | Connecting to the server 127.0.0.1. Port 61006 | 2019-05-02 19:08:12 DTC Client socket (1) | Creating socket. | 2019-05-02 19:08:12 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 19:08:12 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 19:08:13 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 19:08:13 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:08:13 DTC Client socket (1) | Closed. | 2019-05-02 19:08:13 Rithmic Trading | Disconnected. | 2019-05-02 19:08:13 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:08:13 Rithmic Trading | Port for executable: 61013 | 2019-05-02 19:08:15 Listening socket (1868). Port 61013 | Closed. | 2019-05-02 19:08:15 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 19:08:15 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:61013. Current folder: C:\SierraChart\Rim | 2019-05-02 19:08:15 Rithmic Trading | Bridge process is not running! | 2019-05-02 19:08:17 Rithmic Trading | Connecting to the server 127.0.0.1. Port 61013 | 2019-05-02 19:08:17 DTC Client socket (1) | Creating socket. | 2019-05-02 19:08:17 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 19:08:17 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 19:08:18 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 19:08:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:08:18 DTC Client socket (1) | Closed. | 2019-05-02 19:08:18 Rithmic Trading | Disconnected. | 2019-05-02 19:08:18 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:08:18 Rithmic Trading | Port for executable: 61022 | 2019-05-02 19:08:20 Listening socket (1536). Port 61022 | Closed. | 2019-05-02 19:08:20 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 19:08:20 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:61022. Current folder: C:\SierraChart\Rim | 2019-05-02 19:08:20 Rithmic Trading | Bridge process is not running! | 2019-05-02 19:08:22 Rithmic Trading | Connecting to the server 127.0.0.1. Port 61022 | 2019-05-02 19:08:22 DTC Client socket (1) | Creating socket. | 2019-05-02 19:08:22 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 19:08:22 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 19:08:23 * DTC Client socket (1) | Closed. | 2019-05-02 19:08:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 19:08:23 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:08:23 Rithmic Trading | Disconnected. | 2019-05-02 19:08:24 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 19:08:24 Rithmic Trading | Port for executable: 61029 | 2019-05-02 19:08:26 Listening socket (1744). Port 61029 | Closed. | 2019-05-02 19:08:26 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 19:08:26 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:61029. Current folder: C:\SierraChart\Rim | 2019-05-02 19:08:26 File >> Disconnect selected. | 2019-05-02 19:08:26 Rithmic Trading | Disconnected. | 2019-05-02 19:08:26 Checking for new symbol settings. Requested symbol settings MD5 for service code oec. Request ID: 2. | 2019-05-02 19:14:51 Current selected Data/Trading service: GAIN Capital/OEC | 2019-05-02 19:14:51 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2019-05-02 19:14:51 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Connecting to IP: 46.4.97.203. | 2019-05-02 19:14:51 Symbol settings MD5 received. Request ID: 2. | 2019-05-02 19:14:52 Requested symbol settings for service code oec. Request ID: 3. Overwrite = on. | 2019-05-02 19:14:52 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Creating socket. Using TLS 1.2. | 2019-05-02 19:14:52 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Connecting to IP: 46.4.97.203. | 2019-05-02 19:14:52 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close. | 2019-05-02 19:14:52 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2019-05-02 19:14:52 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Closed. | 2019-05-02 19:14:52 Symbol settings received. Request ID: 3. | 2019-05-02 19:14:52 Processed 984 symbol settings. | 2019-05-02 19:14:52 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Shutdown started. Waiting for graceful close. | 2019-05-02 19:14:53 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Socket gracefully closed by remote side. | 2019-05-02 19:14:53 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Closed. | 2019-05-02 19:14:53 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-05-02 19:14:54 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-05-02 19:14:54 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-05-02 19:14:54 GAIN Capital FIX Trading: Sending the Logon message. | 2019-05-02 19:14:54 GAIN Capital FIX Trading | Connected to trading server. | 2019-05-02 19:14:55 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-05-02 19:14:55 GAIN Capital FAST Data socket (2) | Creating socket. | 2019-05-02 19:14:55 GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-05-02 19:14:55 GAIN Capital FAST Data: Sent the Hello message. | 2019-05-02 19:14:55 GAIN Capital FAST Data: Sent the Logon message. | 2019-05-02 19:14:55 GAIN Capital/OEC | Connected to data and trading server. | 2019-05-02 19:14:55 GAIN Capital/OEC | Starting real-time market data updates for: ESM19. ID: 1 Service code: oec | 2019-05-02 19:14:55 GAIN Capital/OEC | Requesting security definition data for: ESM19. ID: 1 | 2019-05-02 19:14:55 Intraday data recording state for symbol ESM19 is set to download 'Pending'. | 2019-05-02 19:14:55 Delaying start of download for ESM19 | 2019-05-02 19:14:55 Requesting market depth updates for: ESM19 if supported. | 2019-05-02 19:14:55 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESM19.2019-05-03.depth | 2019-05-02 19:14:55 HD Request # 2 | Downloading Intraday chart data for ESM19 to the file ESM19.scid. Service: oec | 2019-05-02 19:15:00 HD Request # 2 | Download start date-time: 2019-05-02 15:59:59.000 | 2019-05-02 19:15:00 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2019-05-02 19:15:00 Socket (3) | Creating socket. | 2019-05-02 19:15:00 Socket (3) | Connecting to IP: 192.81.56.146. | 2019-05-02 19:15:00 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2019-05-02 19:15:00 HD Request # 2 | Setting DTC encoding to Binary VLS | 2019-05-02 19:15:00 HD Request # 2 | Sending historical data logon request message. | 2019-05-02 19:15:00 HD Request # 2 | Requesting Intraday data. Start date-time: 2019-05-02 15:59:59. Record interval: 0. Symbol: ESM19 | 2019-05-02 19:15:01 HD Request # 2 | Decompressing data. | 2019-05-02 19:15:01 HD Request # 2 | Receiving Intraday data for ESM19 starting at 2019-05-02 15:59:59 | 2019-05-02 19:15:01 HD Request # 2 | Timestamp of first Intraday data file record written: 2019-05-02 17:00:00 | 2019-05-02 19:15:01 Historical data download thread signaled to stop. | 2019-05-02 19:15:01 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-05-02 19:15:01 HD Request # 2 | Received 6285 records from 2019-05-02 15:59:59 to 2019-05-02 19:14:58 (3.2 hours) and wrote 6279 records for ESM19 | 2019-05-02 19:15:01 HD Request # 2 | Completion time: 0s | 2019-05-02 19:15:01 HD Request # 2 | Intraday data download complete for ESM19. Unique request ID: 1 | 2019-05-02 19:15:01 Removed historical data download ID 1 | 2019-05-02 19:15:01 Real-time Intraday chart data file updates started for ESM19 | 2019-05-02 19:15:01 Intraday chart data file opened for ESM19 | 2019-05-02 19:15:01 Socket (3) | Socket gracefully closed by remote side. | 2019-05-02 19:15:02 Socket (3) | Closed. | 2019-05-02 19:15:02 Opened cached Intraday file: C:\SierraChart\Data\ESM19.scid | 2019-05-02 19:15:04 ESM19 0.25 Range #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:15:05 ESm19 Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:15:05 ESM19 1.75 Range #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:15:05 ESm19 Renko 2t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:15:05 ESM19 0.25 Range #5 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-05-02 19:15:11 ESm19 Renko 4t #4 | StartDateTimeForLoadingOrderFills: 2019-03-03 17:00:00 | 2019-05-02 19:15:11 ESM19 1.75 Range #3 | StartDateTimeForLoadingOrderFills: 2019-04-02 17:00:00 | 2019-05-02 19:15:11 ESm19 Renko 2t #1 | StartDateTimeForLoadingOrderFills: 2019-03-03 17:00:00 | 2019-05-02 19:15:11 File >> Disconnect selected. | 2019-05-02 19:15:28 GAIN Capital FIX Trading: DisconnectFIX called. | 2019-05-02 19:15:28 GAIN Capital FIX Trading: Sending a Logout message. | 2019-05-02 19:15:28 GAIN Capital/OEC | Disconnected from the trading server. | 2019-05-02 19:15:28 GAIN Capital FAST Data: Sent a Logout message. | 2019-05-02 19:15:28 GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-05-02 19:15:28 GAIN Capital/OEC | Disconnected. | 2019-05-02 19:15:28 GAIN Capital FAST Data socket (2) | Socket gracefully closed by remote side. | 2019-05-02 19:15:28 GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-05-02 19:15:28 GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-05-02 19:15:28 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-05-02 19:15:28 GAIN Capital FIX Trading socket (1) | Closed. | 2019-05-02 19:15:28 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2019-05-02 19:15:28 GAIN Capital FAST Data socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-05-02 19:15:28 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2019-05-02 19:15:28 GAIN Capital FAST Data socket (2) | Closed. | 2019-05-02 19:15:28 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-05-02 19:15:40 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-05-02 19:15:40 GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2019-05-02 19:15:40 GAIN Capital FIX Trading: Sending the Logon message. | 2019-05-02 19:15:40 GAIN Capital FIX Trading | Connected to trading server. | 2019-05-02 19:15:41 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-05-02 19:15:41 GAIN Capital FAST Data socket (2) | Creating socket. | 2019-05-02 19:15:41 GAIN Capital FAST Data socket (2) | Connecting to IP: 64.94.37.222. | 2019-05-02 19:15:41 GAIN Capital FAST Data: Sent the Hello message. | 2019-05-02 19:15:41 GAIN Capital FAST Data: Sent the Logon message. | 2019-05-02 19:15:41 GAIN Capital/OEC | Connected to data and trading server. | 2019-05-02 19:15:41 GAIN Capital/OEC | Starting real-time market data updates for: ESM19. ID: 1 Service code: oec | 2019-05-02 19:15:41 GAIN Capital/OEC | Requesting security definition data for: ESM19. ID: 1 | 2019-05-02 19:15:41 Intraday data recording state for symbol ESM19 is set to download 'Pending'. | 2019-05-02 19:15:41 Delaying start of download for ESM19 | 2019-05-02 19:15:41 Requesting market depth updates for: ESM19 if supported. | 2019-05-02 19:15:41 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESM19.2019-05-03.depth | 2019-05-02 19:15:41 ESm19 Renko 2t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:15:44 ESM19 0.25 Range #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:15:44 ESm19 Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:15:44 ESM19 1.75 Range #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:15:44 HD Request # 3 | Downloading Intraday chart data for ESM19 to the file ESM19.scid. Service: oec | 2019-05-02 19:15:46 HD Request # 3 | Download start date-time: 2019-05-02 19:15:18.000 | 2019-05-02 19:15:46 HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2019-05-02 19:15:46 Socket (3) | Creating socket. | 2019-05-02 19:15:46 Socket (3) | Connecting to IP: 65.182.172.42. | 2019-05-02 19:15:46 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2019-05-02 19:15:46 HD Request # 3 | Setting DTC encoding to Binary VLS | 2019-05-02 19:15:47 HD Request # 3 | Sending historical data logon request message. | 2019-05-02 19:15:47 HD Request # 3 | Requesting Intraday data. Start date-time: 2019-05-02 19:15:18. Record interval: 0. Symbol: ESM19 | 2019-05-02 19:15:47 HD Request # 3 | Decompressing data. | 2019-05-02 19:15:47 HD Request # 3 | Receiving Intraday data for ESM19 starting at 2019-05-02 19:15:18 | 2019-05-02 19:15:47 HD Request # 3 | Timestamp of first Intraday data file record written: 2019-05-02 19:15:42 | 2019-05-02 19:15:47 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-05-02 19:15:47 Historical data download thread signaled to stop. | 2019-05-02 19:15:47 HD Request # 3 | Received 2 records from 2019-05-02 19:15:18 to 2019-05-02 19:15:42 (24.0 seconds) and wrote 1 record for ESM19 | 2019-05-02 19:15:47 HD Request # 3 | Completion time: 0s | 2019-05-02 19:15:47 HD Request # 3 | Intraday data download complete for ESM19. Unique request ID: 2 | 2019-05-02 19:15:47 Removed historical data download ID 2 | 2019-05-02 19:15:47 Real-time Intraday chart data file updates started for ESM19 | 2019-05-02 19:15:47 Intraday chart data file opened for ESM19 | 2019-05-02 19:15:47 Socket (3) | Socket gracefully closed by remote side. | 2019-05-02 19:15:47 Socket (3) | Closed. | 2019-05-02 19:15:47 Opened cached Intraday file: C:\SierraChart\Data\ESM19.scid | 2019-05-02 19:15:49 ESM19 0.25 Range #5 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-05-02 19:16:56 ESm19 Renko 4t #4 | StartDateTimeForLoadingOrderFills: 2019-03-03 17:00:00 | 2019-05-02 19:16:56 ESM19 1.75 Range #3 | StartDateTimeForLoadingOrderFills: 2019-04-02 17:00:00 | 2019-05-02 19:16:56 ESm19 Renko 2t #1 | StartDateTimeForLoadingOrderFills: 2019-03-03 17:00:00 | 2019-05-02 19:16:56 ESM19 1.75 Range #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:17:02 ESm19 Renko 2t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:17:02 ESM19 0.25 Range #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:17:02 ESm19 Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-05-02 19:17:02 GAIN Capital FIX Trading: DisconnectFIX called. | 2019-05-02 20:06:27 GAIN Capital FIX Trading: Sending a Logout message. | 2019-05-02 20:06:27 GAIN Capital/OEC | Disconnected from the trading server. | 2019-05-02 20:06:27 GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-05-02 20:06:27 GAIN Capital FAST Data: Sent a Logout message. | 2019-05-02 20:06:27 GAIN Capital/OEC | Disconnected. | 2019-05-02 20:06:27 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2019-05-02 20:06:27 GAIN Capital FAST Data socket (2) | Write in progress. Shutdown being delayed. | 2019-05-02 20:06:27 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2019-05-02 20:06:27 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (3) | Creating socket. Using TLS 1.2. | 2019-05-02 20:06:27 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 4. | 2019-05-02 20:06:27 Current selected Data/Trading service: Rithmic Trading | 2019-05-02 20:06:27 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (3) | Connecting to IP: 46.4.97.203. | 2019-05-02 20:06:27 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:27 GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-05-02 20:06:27 GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-05-02 20:06:27 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-05-02 20:06:27 GAIN Capital FIX Trading socket (1) | Closed. | 2019-05-02 20:06:27 GAIN Capital FAST Data socket (2) | Socket gracefully closed by remote side. | 2019-05-02 20:06:27 GAIN Capital FAST Data socket (2) | Write has completed. Shutdown being performed. | 2019-05-02 20:06:27 GAIN Capital FAST Data socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-05-02 20:06:27 GAIN Capital FAST Data socket (2) | Closed. | 2019-05-02 20:06:27 Symbol settings MD5 received. Request ID: 4. | 2019-05-02 20:06:28 Requested symbol settings for service code rithmic.trading. Request ID: 5. Overwrite = on. | 2019-05-02 20:06:28 HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (1) | Creating socket. Using TLS 1.2. | 2019-05-02 20:06:28 HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (1) | Connecting to IP: 46.4.97.203. | 2019-05-02 20:06:28 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (3) | Shutdown started. Waiting for graceful close. | 2019-05-02 20:06:28 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (3) | Socket gracefully closed by remote side. | 2019-05-02 20:06:28 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (3) | Closed. | 2019-05-02 20:06:28 Symbol settings received. Request ID: 5. | 2019-05-02 20:06:28 Processed 955 symbol settings. | 2019-05-02 20:06:28 HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (1) | Shutdown started. Waiting for graceful close. | 2019-05-02 20:06:29 HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (1) | Socket gracefully closed by remote side. | 2019-05-02 20:06:29 HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (1) | Closed. | 2019-05-02 20:06:29 Rithmic Trading | Port for executable: 64912 | 2019-05-02 20:06:29 Listening socket (1800). Port 64912 | Closed. | 2019-05-02 20:06:29 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 20:06:29 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64912. Current folder: C:\SierraChart\Rim | 2019-05-02 20:06:29 Rithmic Trading | Bridge process is running. | 2019-05-02 20:06:31 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64912 | 2019-05-02 20:06:31 DTC Client socket (1) | Creating socket. | 2019-05-02 20:06:31 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 20:06:31 Rithmic Trading | Connected to server. | 2019-05-02 20:06:31 Rithmic Trading | Starting socket receive thread. | 2019-05-02 20:06:31 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-05-02 20:06:31 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-05-02 20:06:31 Rithmic Trading | Sending logon request message. | 2019-05-02 20:06:31 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-05-02 20:06:31 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-05-02 20:06:31 Rithmic Trading | Message from server: Connecting to Rithmic Topstep Trader server. | 2019-05-02 20:06:31 Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-05-02 20:06:36 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-05-02 20:06:36 Rithmic Trading | Received logon response. | 2019-05-02 20:06:36 Rithmic Trading | Server Name: DTC Bridge. | 2019-05-02 20:06:36 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-05-02 20:06:36 Rithmic Trading | Logon error received from server | 2019-05-02 20:06:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 20:06:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:36 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-05-02 20:06:36 DTC Client socket (1) | Closed. | 2019-05-02 20:06:36 Rithmic Trading | Disconnected. | 2019-05-02 20:06:36 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:36 Rithmic Trading | Port for executable: 64931 | 2019-05-02 20:06:38 Listening socket (1732). Port 64931 | Closed. | 2019-05-02 20:06:38 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 20:06:38 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64931. Current folder: C:\SierraChart\Rim | 2019-05-02 20:06:38 Rithmic Trading | Bridge process is not running! | 2019-05-02 20:06:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64931 | 2019-05-02 20:06:40 DTC Client socket (1) | Creating socket. | 2019-05-02 20:06:40 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 20:06:40 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 20:06:41 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 20:06:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:41 DTC Client socket (1) | Closed. | 2019-05-02 20:06:41 Rithmic Trading | Disconnected. | 2019-05-02 20:06:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:41 Rithmic Trading | Port for executable: 64938 | 2019-05-02 20:06:43 Listening socket (1628). Port 64938 | Closed. | 2019-05-02 20:06:43 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 20:06:43 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64938. Current folder: C:\SierraChart\Rim | 2019-05-02 20:06:43 Rithmic Trading | Bridge process is not running! | 2019-05-02 20:06:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64938 | 2019-05-02 20:06:45 DTC Client socket (1) | Creating socket. | 2019-05-02 20:06:45 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 20:06:45 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 20:06:46 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 20:06:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:46 DTC Client socket (1) | Closed. | 2019-05-02 20:06:46 Rithmic Trading | Disconnected. | 2019-05-02 20:06:46 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:46 Rithmic Trading | Port for executable: 64945 | 2019-05-02 20:06:48 Listening socket (1776). Port 64945 | Closed. | 2019-05-02 20:06:48 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 20:06:48 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64945. Current folder: C:\SierraChart\Rim | 2019-05-02 20:06:48 Rithmic Trading | Bridge process is not running! | 2019-05-02 20:06:50 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64945 | 2019-05-02 20:06:50 DTC Client socket (1) | Creating socket. | 2019-05-02 20:06:50 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 20:06:50 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 20:06:51 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 20:06:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:51 DTC Client socket (1) | Closed. | 2019-05-02 20:06:51 Rithmic Trading | Disconnected. | 2019-05-02 20:06:51 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:51 Rithmic Trading | Port for executable: 64953 | 2019-05-02 20:06:53 Listening socket (1968). Port 64953 | Closed. | 2019-05-02 20:06:53 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 20:06:53 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64953. Current folder: C:\SierraChart\Rim | 2019-05-02 20:06:53 Rithmic Trading | Bridge process is not running! | 2019-05-02 20:06:55 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64953 | 2019-05-02 20:06:55 DTC Client socket (1) | Creating socket. | 2019-05-02 20:06:55 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 20:06:55 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 20:06:56 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 20:06:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:56 DTC Client socket (1) | Closed. | 2019-05-02 20:06:56 Rithmic Trading | Disconnected. | 2019-05-02 20:06:56 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:06:56 Rithmic Trading | Port for executable: 64960 | 2019-05-02 20:06:58 Listening socket (2036). Port 64960 | Closed. | 2019-05-02 20:06:58 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-05-02 20:06:58 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64960. Current folder: C:\SierraChart\Rim | 2019-05-02 20:06:58 Rithmic Trading | Bridge process is not running! | 2019-05-02 20:07:00 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64960 | 2019-05-02 20:07:00 DTC Client socket (1) | Creating socket. | 2019-05-02 20:07:00 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-05-02 20:07:00 DTC Client socket (1) | Connect event error. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2019-05-02 20:07:01 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-02 20:07:01 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:07:01 DTC Client socket (1) | Closed. | 2019-05-02 20:07:01 Rithmic Trading | Disconnected. | 2019-05-02 20:07:01 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-02 20:07:01 |
[2019-05-03 03:10:33] |
This is the problem: Rithmic Trading | Message from server: Error creating the main object. Error message: os error | This particular Rithmic error we cannot help with. We are working on a new interface to Rithmic which will overcome this kind of problem but that is not yet available. What we can do for you for now is give you a refund. We wish we could help better with this, but we just cannot. And also for the record that error message originates from Rithmic's own software. Not Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-03 03:10:39
