Date/Time: Fri, 31 Jan 2025 12:03:05 +0000
SC on Surface Pro.
View Count: 1213
[2019-05-02 22:55:03]
User401511 - Posts: 33
Hi, I downloaded SC onto a SSD Portable HD on with my Surface Pro 5 tablet/computer.
I can open SC on multiple machines from my portable SSD.
However, The Font size on my chart is weird. I don't know if it is from update or if its because I downloaded SC with my Surface pro ( 12.5" screen).
Is it supposed to look like this now? If not can it be corrected? thanks!
http://www.sierrachart.com/image.php?Image=1556837643755.png
imagescscreenshot.jpg / V - Attached On 2019-05-02 22:50:33 UTC - Size: 321.65 KB - 282 views
[2019-05-03 03:11:35]
think I got it. I originally downloaded SC onto SSD portable on my surface pro. The resolution or screen size must have something to do with my problem.
Deleted off portable ssd and reinstalled from desktop and problem solved.
[2019-05-03 14:39:46]
Here is the documentation to adjust fonts:
Graphics Settings: Fonts and Text Appearance
We would not expect this to change the fonts at all.
Date Time Of Last Edit: 2019-05-03 14:40:27
