Date/Time: Fri, 31 Jan 2025 11:56:40 +0000
Rhitmic Trading whit TopStep Trader
View Count: 873
[2019-05-02 21:10:25] |
User851645 - Posts: 2 |
hi i have a problem with the connection datafeed Rhitmic Trading whit TopStep Trader, there are mine credentials : I tried login whit R-Trader of Rhitmic and it's OK, but whit sierra chart fail. I sent message log Date Time Of Last Edit: 2019-05-02 21:31:08
Private File |
[2019-05-03 03:09:19] |
This is the problem: Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2019-05-02 15:55:04 This particular Rithmic error we cannot help with. We are working on a new interface to Rithmic which will overcome this kind of problem but that is not yet available. What we can do for you for now is give you a refund. We wish we could help better with this, but we just cannot. And also for the record that error message originates from Rithmic's own software. Not Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-03 03:09:59
