Date/Time: Fri, 31 Jan 2025 10:46:57 +0000
Setting up Attached Orders with Multiple Stop Types
View Count: 783
[2019-05-02 18:09:44]
User836689 - Posts: 12
I would like help setting up the following attached order:
1. 5 contracts - 2 @ 3 ticks, 2 @ 6 ticks, 12 tick stop with move to b/e after 4 ticks and 1 trailing stop with 4 trigger offset and 1.5 tick trail.
Not sure if you can combine the two stop types, so I would appreciate your help.
[2019-05-05 17:52:10]
Attached is a trade window configuration file which is the closest to what you specified. The only difference is that even ticks are used. It is not possible to use a half tick and the second target is three contracts.
Instructions:
Basic Trading and the Trade Window: Using a Trade Window Configuration File Provided to You
Date Time Of Last Edit: 2019-05-05 17:53:43
attachmentUser836689_TradeStrategy.twconfig - Attached On 2019-05-05 17:51:29 UTC - Size: 6.52 KB - 320 views
