Date/Time: Fri, 31 Jan 2025 11:53:17 +0000
Video
View Count: 951
[2019-05-02 18:08:03] |
Jeffrey S - Posts: 42 |
Does Sierra have a function that records my trading?
[2019-05-02 20:04:29] |
No this is not supported but you can replay charts. And you can display historical order fills the chart: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-02 20:09:27] |
Can I replay the DOMs?
[2019-05-02 20:31:16] |
Yes. Refer to this page: Replaying Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-02 20:31:25
[2019-05-03 04:43:40] |
Merlin - Posts: 83 |
The open source program OBS Studio works well for recording Sierra. It's fairly low on resource use, and you can control that by reducing the frames per second. https://obsproject.com/ Merlin |
