Date/Time: Fri, 31 Jan 2025 10:45:25 +0000
Bid and Ask Depth Bars not saving
View Count: 657
[2019-05-02 17:13:31] |
samual sprat - Posts: 343 |
Hi, I've got Bid and Ask Depth Bars loaded on my chart and i've enabled global symbol settings>intraday>record market depth. Depth bars stay on screen for about 20-30m then they are truncated and disappear. Any idea what could be causing this? Thanks S |
[2019-05-02 20:05:36] |
The conditions under which this can occur is explained in the documentation here if you are using the Time and Sales data: Bid & Ask Depth Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-02 20:06:42
