Date/Time: Fri, 31 Jan 2025 10:47:10 +0000
Cummulative TICK
View Count: 819
[2019-05-02 16:02:13] |
User371906 - Posts: 141 |
Hello, Does SC have a Cummulative TICKBA-NASDAQ? Need to place the TICKBA-NASDAQ in subgraph Draw Style as histogram. Thank You |
[2019-05-02 20:57:20] |
You should use TICK-NASDAQ. We will be removing the TICKBA symbol since all of the market statistics symbols now include bid and ask updates based on certain rules as explained here: Sierra Chart Market Statistics Calculations Change To do a Cumulative calculation use this study: Cumulative Sum of Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-02 20:58:42
