Date/Time: Fri, 31 Jan 2025 11:59:24 +0000
Global profit and loss help
View Count: 1514
[2019-05-02 15:38:24] |
User968625 - Posts: 260 |
I am really struggling to understand why this is not working right for me. I must be doing something wrong or really stupid. First, I have 600 loss target but doesn't seem to work. I am attaching an image (JPG and PNG as SC images can't be selected when I am choosing to see this window). can someone help if these settings are correct to lock my trading for the day once I reach my limit? (of course, unless I intervene manually)and is there a way that I can't even intervene? Second, I am not sure I understand "Trail Daily net profit", can someone just give an example or two? I want to have a target of 1200 and once I lose more than 300 of that it is locked as Loss management? I know there is documentation but couldn't understand the explanation (probably it is just me being stupid) Thank you |
Global Profit and Loss.jpg / V - Attached On 2019-05-02 15:34:51 UTC - Size: 156.86 KB - 347 views Global Profit and Loss.png / V - Attached On 2019-05-02 15:34:59 UTC - Size: 52.91 KB - 525 views |
[2019-05-03 19:47:13] |
The settings here are correct: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=28084 . can someone help if these settings are correct to lock my trading for the day once I reach my limit? Yes.Use the following settings: Daily Net Profit Management >> Profit Trigger Value=1200 Daily Net Profit Management >> Profit Value After Trigger To Flatten Positions= 900 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-03 19:47:51
[2019-05-03 20:50:45] |
Thank you, tried he setting today with small amount and did work. I am going to try now the profit value setting you gave. you have an amzaing platform, thank you again
[2019-05-04 02:58:03] |
Good. It is also important to read over the Introduction section here to understand how the net profit/loss is arrived at and to make sure the calculations are correct: Global Profit/Loss Management: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
