Date/Time: Fri, 31 Jan 2025 11:53:08 +0000
chart not opdating
View Count: 752
[2019-05-02 15:04:15] |
kcarey - Posts: 33 |
after updating sierra my gdxj-stk-smart{arca shows up as gdxj-stk-smart/arca and will load but not update. After trying to open it anew it will still revert back to the / and notupdate actively.
[2019-05-02 20:19:05] |
gdxj-stk-smart/arca is the symbol you should see in the chart. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-08 14:26:43] |
I have followed all directions. Been here over 12 years. No matter what I do GDXJ will load BUT NOT UPDATE.
[2019-05-08 16:18:09] |
