Date/Time: Fri, 31 Jan 2025 10:57:23 +0000
Tile as Grid Functionaly changed
View Count: 817
[2019-05-02 07:07:30] |
ILIM KIRGIZ - Posts: 187 |
Dear Support, I use v1915 64-bit. With old chartbook architecture, When I use Window>Tile as Grid Vertically function all charts were occupying entire space even though there are some open spreadsheets. Now they are not. See attached screenshot. |
Attachment Deleted. Capture.PNG / V - Attached On 2019-05-02 07:07:18 UTC - Size: 386.29 KB - 284 views |
[2019-05-02 22:47:03] |
Nothing has changed with this functionality but we will look into this.
