Date/Time: Tue, 04 Nov 2025 18:08:36 +0000
Price scale has gone missing
View Count: 3384
| [2013-04-10 13:32:21] |
| rustydog - Posts: 2 |
Hi just updated to newest ver sc and the price scale has gone missing in a bunch of charts along with the horizontal grid.it does the last price box though.i have tried restarting computer and tried differnt background colors for price grid. thanks! http://www.sierrachart.com/image.php?l=1365600713362.png |
| [2013-04-10 14:49:13] |
Hi I should add its not all symbols and if i close the chart and re open it the price scale does show up for a second then dissapears again.
| [2013-04-10 16:50:27] |
It appears as though the Tick Size is not set correctly in Chart >> Chart Settings.
