Date/Time: Fri, 31 Jan 2025 10:42:19 +0000
Market Depth
View Count: 625
[2019-05-01 16:08:03] |
User417302 - Posts: 67 |
Quick question - I only want to see 10 levels of depth on the dom however it seems that I’m seeing way more than that. I realize that 200 levels are offered but I don’t need to see that much. My setting for depth in chart setting are set to 10. How do I change the settings to minimize the amount of depth shown? Thanks |
[2019-05-01 21:13:05] |
John - SC Support - Posts: 37621 |
To display only a certain number of market depth levels in the DOM, refer to the following setting: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-01 21:51:20
[2019-05-01 23:15:33] |
You will also want to reduce this setting to reduce the bandwidth usage: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels This setting requires the current version of Sierra Chart: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
