Date/Time: Fri, 31 Jan 2025 20:19:42 +0000
Chart Dom Bid Market Depth Pulling/Stacking Negative doesn't work
View Count: 1230
[2019-05-01 15:48:26] |
IconBob - Posts: 61 |
Same with Chart Dom Ask Market Depth Pulling/Stacking Negative Colors don't change.
Date Time Of Last Edit: 2019-05-01 15:49:29
2019-05-01_11-38-17.jpg / V - Attached On 2019-05-01 15:42:23 UTC - Size: 123.42 KB - 576 views |
[2019-05-01 23:03:49] |
Yes we are aware of this. Those settings are not yet implemented.
[2019-05-01 23:31:32] |
I am now. So, that explains it.
[2019-06-03 05:34:47] |
Acro - Posts: 441 |
Hi Any update on when the negative pullstack setting will become active ? Thanks |
[2019-06-04 10:45:34] |
This is now in version 1929.
