Date/Time: Fri, 31 Jan 2025 10:44:36 +0000
Delayed Candle update
View Count: 564
[2019-05-01 15:10:18]
User747368 - Posts: 18
This issue started today. On chart, price is updating normally along y axis, but there is a delay with candle updating. This is not an issue for second instance of SC. Unable to find a settings discrepancy between the two instances. Running most recent version 1914. Any ideas on this one?
Thanks for your help.
Tim
[2019-05-01 23:02:36]
We see you are using Interactive Brokers. Make sure you disable the use of true real-time data:
https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#TrueRealTimeData
[2019-05-01 23:26:19]
Thank you! Issue resolved.
