Date/Time: Fri, 31 Jan 2025 10:33:21 +0000
Dissappering Tabs
View Count: 683
[2019-05-01 14:59:10] |
Ken Burks - Posts: 7 |
Yesterday, I downloaded Ver 1913 and my tabs keep dissapering. Thoughts?
[2019-05-01 16:55:32] |
John - SC Support - Posts: 37621 |
This is related to the new tab controls that were recently released. First, update to version 1915, as it has some fixes for the tab controls and see if your issue is resolved. Be aware, that the workaround is to simply select the arrows on the far right side to get the tabs to show up. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-01 19:12:46] |
Thanks- 1915 fixed it
