Date/Time: Fri, 31 Jan 2025 10:43:39 +0000
Trendlines synchrone 2000t chart or 15min chart
View Count: 724
[2019-05-01 13:09:29] |
User613910 - Posts: 45 |
Hi, When I draw a trendline on my 2000t chart the line is not correct if I turn the same chart in 15min. How can I synchronise the lines exact on the same places no matter what chart I use? Already thanks, Anita |
[2019-05-02 02:50:35] |
It is hard for us to know what the specific issue is in this particular case but in general, refer to this section and the one below: Lines/Rays or Other Chart Drawings Move After Drawing Them: How Chart Drawings Are Mapped Between Bars with Different Starting Date-Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-02 02:50:50
