Date/Time: Fri, 31 Jan 2025 12:49:46 +0000
Iqfeed with IB
View Count: 1254
[2019-04-30 15:51:33]
User699722 - Posts: 7
Can I use a SINGLE SC instance for the above or I have to run one SC instance for Interactive Brokers and one for IQFeed ?Do I still need two instances? I heard you're working on it.
-Trading Service - Interactive Brokers
- Market Data Service - IQFeed
[2019-04-30 18:42:08]
You need two separate instances for this. And refer to:
https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart
Although you really should use the Sierra Chart Exchange Data Feed to access a good quality data feed in the instance of Sierra Chart connected to Interactive Brokers:
In this way you just need one instance and it is a lot lower cost.
Date Time Of Last Edit: 2019-04-30 18:42:38
[2019-05-01 15:10:38]
Im still having issues on connecting with IB, is there any chart set up videos with IB you can refer to?
[2019-05-01 18:05:35]
John - SC Support - Posts: 37621
Refer to the Setup Instructions for Interactive Brokers here:
Interactive Brokers Trading Service: Setup Instructions
[2019-05-02 05:06:09]
Is there any easier way of setting up of sierra chart with IB and market data IQfeed. With that link ,im unable to get it going.
-I got two instances running, one for iqfeed and other one set to sub instance. Thanks
[2019-05-02 12:54:21]
No, there is not. Why not use the Sierra Chart Exchange Data Feed instead? It is less expensive.
[2019-05-02 15:53:58]
I trade CME Emini ,so which data package should i subscribe,what's the monthly pricing? i want to give it try as im having issues on running
two copies of SC for IB and IQFEED? Thanks
[2019-05-02 17:00:42]
I subscribed market data but i dont see Emini s&p 500,Emini NQ,RTY,YM symbol,which package should i get?thanks
[2019-05-02 20:07:39]
You need to connect Sierra Chart to your Interactive Brokers account and be using the Interactive Brokers symbols:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices
[2019-05-10 01:57:32]
Mid point (daily high and low average) is way off, is there anyway I can fix it up?Thank you
[2019-05-10 02:40:52]
This is too vague for us to help with. Specifically what are you referring to? And how are you coming to that conclusion? If you are referring to a study we need to know which study.
Provide an image of the chart or Trade DOM, by following these instructions:
