Date/Time: Fri, 31 Jan 2025 08:48:04 +0000
Line from right edge fixed width
View Count: 1132
[2019-04-30 11:57:33] |
grantx - Posts: 244 |
I have some lines that adjust as price moves up and down. I want these pivot lines to maintain a set distance away from the right edge. In the 1st image, the lines project from last bar to the edge. This is distracting. I would like it to function as in the 2nd image. How do I do it? Date Time Of Last Edit: 2019-04-30 11:58:37
[2019-04-30 12:38:53] |
The closest that it is available is just to display the name and value labels only by using this particular Draw Style: Chart Studies: Subgraph Name and Value Labels Only (ACSIL: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
