Date/Time: Fri, 31 Jan 2025 08:41:32 +0000
Why Do I have to setup every Symbol separate?
View Count: 551
[2019-04-30 02:05:32] |
ArtemisX23 - Posts: 1 |
Im setting up the Market Profile and I having to setup each symbol separate, setup the same settings over and over and then save each symbol so I wont lose the info. Is that how it's supposed to be? Im new to Sierra charts so thought to ask before continuing I still have about 25 more tickers to setup. Thanks |
[2019-04-30 02:48:31] |
We recommend using the duplicate chart functionality to make this much easier: Using Chart Templates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
