Date/Time: Fri, 31 Jan 2025 08:50:04 +0000
Oldest Intraday $VIX Data Available?
View Count: 586
[2019-04-29 18:22:41] |
User279754 - Posts: 38 |
I have the CBOE Indices data activated, so I have real-time intraday $VIX data and this also gives me access to historical intraday $VIX going back to about May 2010. I would like to get intraday VIX data back to 2007 or so, if possible. Do you have any suggested solutions? I don't need it at tick level, just 1-min or 2-min intervals is fine.
[2019-04-30 02:38:29] |
We would have to check but if you can get back to 2010, that would sound like all that is available. We are not sure where else you can get any additional data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
