Date/Time: Thu, 26 Sep 2024 23:31:22 +0000
tape
View Count: 1378
[2013-11-22 18:49:10] |
gary - Posts: 3 |
how do I get a tape chart up?
[2013-11-22 18:58:21] |
What is a tape chart?
[2013-11-22 19:00:19] |
sbsierra - Posts: 71 |
http://www.sierrachart.com/index.php?l=doc/doc_TimeandSalesWindow.html
[2013-11-22 19:22:11] |
gary - Posts: 3 |
never mind
[2013-11-22 19:56:36] |
If you are referring to the Time and Sales listing, then you need to use the Time and Sales window. We do not refer to that as a chart. That is a table view. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
