Date/Time: Sat, 20 Apr 2024 00:26:35 +0000
Notice: Studies Compiled With Version 1224 And Lower Will Need To Be Recompiled
View Count: 1943
[2019-04-29 15:40:09] |
Beginning with version 1917 which is now out, studies compiled with version 1224 and older will need to be recompiled to work on this version and later. A recompile can be done through the Analysis >> Build Custom Studies DLL interface. If there any compiler errors, you will just need to correct them. Typically this will be just simply renaming function names and variables. This relates to the development we are doing to support true millisecond time stamping: True Millisecond/Microsecond Time Stamping and ACSIL With the new true millisecond time stamping support, all ACSIL studies will need to be recompiled on the version that has that support so there simply is no need for us to be supporting studies compiled with version 1224 and earlier and we want to start to get those recompiled as soon as possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-11 02:17:33
