Date/Time: Fri, 31 Jan 2025 09:01:35 +0000
Connect Two Systems
View Count: 575
[2019-04-29 14:02:07]
brenanstewart - Posts: 28
On my account control panel, it says that I can connect two systems. In reality, it's only letting me connect one system. Second system is not getting live data
[2019-04-29 14:52:49]
This is a limitation imposed by external services. Not with Sierra Chart itself.
Although we see you are using the Sierra Chart Exchange Data Feed and in that case you would need to activate a second real-time connection:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#DataConnections
Once you do that though, then you will want to follow the method here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ConnectingOnlyOnceAMonthToTradingAccount
To authorize the real-time CME data and then directly connect to SC Data-All Services to work around connection limitations with other services.
Date Time Of Last Edit: 2019-04-29 14:53:21
