Date/Time: Sun, 04 Oct 2026 12:13:57 +0000
DOM responsiveness
View Count: 992
| [2019-04-29 10:41:01] |
| Luke - Posts: 152 |
When I quickly click into the same cell of the DOM BUY or SELL column twice to enter a limit order (ordering twice the amount of contracts set in the trade window as default), the DOM only reacts to the first click, it won't react to additional clicks unless there is a delay after each click. Is there any way to change the reactiveness of the DOM? If for example I have my default number of contracts set to 1 in the trade window, I might want to quickly enter an order for two contracts without having to change the number of contract default settings in the trade window. But this only works if there is a small delay between both clicks, or if I actually click 3 times.
Date Time Of Last Edit: 2019-04-29 12:43:55
| [2019-04-29 12:48:23] |
The operating system is interpreting this as a double-click. The proper procedure is that you need to set the order quantity to 2 on the Trade Window: Basic Trading and the Trade Window: Main >> Order Quantity (Quantity) And then just enter a single order. You can also change the double-click delay within the operating system control panel but that is going to affect the entire system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
