Date/Time: Fri, 31 Jan 2025 09:09:18 +0000
Message Log
View Count: 740
[2019-04-27 10:56:42]
User497586 - Posts: 2
File attached.
Private File
[2019-04-27 23:17:33]
It is not clear what the question is here. Can you let us know.
[2019-04-28 09:45:34]
After I changed the service setting from "SC Data - All Services [data]" to "Interactive Brokers [trading]" in Global Settings >> Data/Trade Service Settings. I have logged-in my Interactive Brokers account and change the service setting back to "SC Data - All Services [data]", in order to get the data feed discount for IB (eligible future broker) user.
When I finished the above setting, I can’t get the real-time data.
Meanwhile, the Message Log periodically open, and the message log shown that the connection to the data and trade server is failed.
How can I fix the problem? Thanks!
Please find attached the message log as below for your reference:
Reading Internal Order ID file. | 2019-04-28 16:35:12
Reading Trade Orders file. | 2019-04-28 16:35:12
Reading Trade Positions file. | 2019-04-28 16:35:12
Reading Account Balance file. | 2019-04-28 16:35:12
UDPListener (1768). Port 22904 | Listening on UDP port 22904. | 2019-04-28 16:35:12
Software version: 1898 32-bit | 2019-04-28 16:35:12
Usage end date: 2019-05-29 | 2019-04-28 16:35:12
Enabled for: Advanced Features. | 2019-04-28 16:35:12
Enabled for: Advanced Features 2. | 2019-04-28 16:35:12
Enabled for: Sierra Chart Historical Data Service. | 2019-04-28 16:35:12
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-04-28 16:35:12
Enabled for: INDEXES_DATA_BARCHART | 2019-04-28 16:35:12
Enabled for: CME (Trading Account Required) | 2019-04-28 16:35:12
Enabled for: CBOT (Trading Account Required) | 2019-04-28 16:35:12
Enabled for: COMEX (Trading Account Required) | 2019-04-28 16:35:12
Enabled for: NYMEX (Trading Account Required) | 2019-04-28 16:35:12
Received 1 data feed usernames. | 2019-04-28 16:35:12
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-04-28 16:35:12
Current selected Data/Trading service: SC Data - All Services | 2019-04-28 16:35:12
Chart Update Interval: 500 | 2019-04-28 16:35:12
Intraday Data Storage Time Unit: 0 | 2019-04-28 16:35:12
Time Zone: +08:00:00 (HKT+08) | 2019-04-28 16:35:12
2019-04-28 16:35:11 Local computer time | 2019-04-28 16:35:12
2019-04-28 08:35:11 Local computer time in UTC | 2019-04-28 16:35:12
2019-04-28 16:35:11 Local computer time in SC Time Zone | 2019-04-28 16:35:12
2019-04-28 08:35:09 Server time in UTC | 2019-04-28 16:35:12
Local computer UTC time and Server UTC time difference: 2 seconds. | 2019-04-28 16:35:12
Program path: C:\SierraChart\ | 2019-04-28 16:35:12
Data Files path: C:\SierraChart\Data\ | 2019-04-28 16:35:12
OS Version Number: 10.0 | 2019-04-28 16:35:12
Locale Setting: C | 2019-04-28 16:35:12
DLLs: Seven_in_One_Advanced_Order_Flow_Tool.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-04-28 16:35:12
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2019-04-28 16:35:12
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-04-28 16:35:12
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-04-28 16:35:12
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-04-28 16:35:12
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-04-28 16:35:12
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-04-28 16:35:12
Received 5 login tokens. | 2019-04-28 16:35:13
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-04-28 16:35:13
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-04-28 16:35:13
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-04-28 16:35:13
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-04-28 16:35:14
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-04-28 16:35:14
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-04-28 16:35:15
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-04-28 16:35:15
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-04-28 16:35:15
Symbol settings MD5 received. Request ID: 1. | 2019-04-28 16:35:16
Symbol settings are up-to-date for scdataallservices. | 2019-04-28 16:35:16
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-04-28 16:35:16
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-04-28 16:35:16
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-04-28 16:35:16
SC Data - All Services | Connected to data server. | 2019-04-28 16:35:18
Notice: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2019-04-28 16:35:18
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:35:18
Socket (1) | Creating socket. | 2019-04-28 16:35:18
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:35:18
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:35:19 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:35:19 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:35:19 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:35:19
Interactive Brokers | Disconnected. | 2019-04-28 16:35:19
Socket (1) | Closed. | 2019-04-28 16:35:19
Loading DLL C:\SierraChart\Data\Seven_in_One_Advanced_Order_Flow_Tool.dll | 2019-04-28 16:35:35
ESM19 [C] 5 Min #1 | Reloading chart. | 2019-04-28 16:35:35
SC Data - All Services | Starting real-time market data updates for: ESM19. ID: 1 | 2019-04-28 16:35:35
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESM19 | 2019-04-28 16:35:35
SC Data - All Services | Requesting security definition data for: ESM19. ID: 1 | 2019-04-28 16:35:35
Intraday data recording state for symbol ESM19 is set to download 'Pending'. | 2019-04-28 16:35:35
Delaying start of download for ESM19 | 2019-04-28 16:35:35
HD Request # 2 | Downloading Intraday chart data for ESM19 to the file ESM19.scid. Service: cme | 2019-04-28 16:35:40
HD Request # 2 | Download start date-time: 2019-04-27 04:59:59.000 | 2019-04-28 16:35:40
HD Request # 2 | Using server: ds7.sierracharts.com port 10150 | 2019-04-28 16:35:40
Socket (1) | Creating socket. | 2019-04-28 16:35:40
Socket (1) | Connecting to IP: 8.18.161.133. | 2019-04-28 16:35:40
HD Request # 2 | Setting DTC encoding to Binary VLS | 2019-04-28 16:35:41
HD Request # 2 | Sending historical data logon request message. | 2019-04-28 16:35:41
HD Request # 2 | Requesting Intraday data. Start date-time: 2019-04-27 04:59:59. Record interval: 0. Symbol: ESM19 | 2019-04-28 16:35:41
HD Request # 2 | Decompressing data. | 2019-04-28 16:35:41
HD Request # 2 | Receiving Intraday data for ESM19 starting at 2019-04-27 04:59:59 | 2019-04-28 16:35:41
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-04-28 16:35:41
Historical data download thread signaled to stop. | 2019-04-28 16:35:41
HD Request # 2 | Received 7 records from 2019-04-27 04:59:59 to 2019-04-27 04:59:59 (0.0 seconds) and wrote 0 records for ESM19 | 2019-04-28 16:35:41
HD Request # 2 | Completion time: 1s | 2019-04-28 16:35:41
HD Request # 2 | Intraday data download complete for ESM19. Unique request ID: 1 | 2019-04-28 16:35:41
Removed historical data download ID 1 | 2019-04-28 16:35:41
Real-time Intraday chart data file updates started for ESM19 | 2019-04-28 16:35:41
Intraday chart data file opened for ESM19 | 2019-04-28 16:35:41
Socket (1) | Socket gracefully closed by remote side. | 2019-04-28 16:35:41
Socket (1) | Closed. | 2019-04-28 16:35:41
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:35:49
Socket (1) | Creating socket. | 2019-04-28 16:35:49
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:35:49
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:35:50 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:35:50 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:35:50 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:35:50
Interactive Brokers | Disconnected. | 2019-04-28 16:35:50
Socket (1) | Closed. | 2019-04-28 16:35:50
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:36:20
Socket (1) | Creating socket. | 2019-04-28 16:36:20
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:36:20
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:36:21 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:36:21 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:36:21 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:36:21
Interactive Brokers | Disconnected. | 2019-04-28 16:36:21
Socket (1) | Closed. | 2019-04-28 16:36:21
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:36:51
Socket (1) | Creating socket. | 2019-04-28 16:36:51
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:36:51
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:36:52 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:36:52 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:36:52 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:36:52
Interactive Brokers | Disconnected. | 2019-04-28 16:36:52
Socket (1) | Closed. | 2019-04-28 16:36:52
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:37:22
Socket (1) | Creating socket. | 2019-04-28 16:37:22
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:37:22
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:37:23 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:37:23 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:37:23 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:37:23
Interactive Brokers | Disconnected. | 2019-04-28 16:37:23
Socket (1) | Closed. | 2019-04-28 16:37:23
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:37:53
Socket (1) | Creating socket. | 2019-04-28 16:37:53
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:37:53
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:37:54 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:37:54 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:37:54 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:37:54
Interactive Brokers | Disconnected. | 2019-04-28 16:37:54
Socket (1) | Closed. | 2019-04-28 16:37:54
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:38:24
Socket (1) | Creating socket. | 2019-04-28 16:38:24
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:38:24
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:38:25 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:38:25 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:38:25 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:38:25
Interactive Brokers | Disconnected. | 2019-04-28 16:38:25
Socket (1) | Closed. | 2019-04-28 16:38:25
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:38:55
Socket (1) | Creating socket. | 2019-04-28 16:38:55
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:38:55
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:38:56 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:38:56 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:38:56 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:38:56
Interactive Brokers | Disconnected. | 2019-04-28 16:38:56
Socket (1) | Closed. | 2019-04-28 16:38:56
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:39:26
Socket (1) | Creating socket. | 2019-04-28 16:39:26
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:39:26
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:39:27 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:39:27 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:39:27 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:39:27
Interactive Brokers | Disconnected. | 2019-04-28 16:39:27
Socket (1) | Closed. | 2019-04-28 16:39:27
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:39:57
Socket (1) | Creating socket. | 2019-04-28 16:39:57
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:39:57
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:39:58 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:39:58 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:39:58 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:39:58
Interactive Brokers | Disconnected. | 2019-04-28 16:39:58
Socket (1) | Closed. | 2019-04-28 16:39:58
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:40:28
Socket (1) | Creating socket. | 2019-04-28 16:40:28
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:40:28
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:40:29 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:40:29 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:40:29 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:40:29
Interactive Brokers | Disconnected. | 2019-04-28 16:40:29
Socket (1) | Closed. | 2019-04-28 16:40:29
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:40:59
Socket (1) | Creating socket. | 2019-04-28 16:40:59
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:40:59
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:41:00 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:41:00 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:41:00 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:41:00
Interactive Brokers | Disconnected. | 2019-04-28 16:41:00
Socket (1) | Closed. | 2019-04-28 16:41:00
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:41:30
Socket (1) | Creating socket. | 2019-04-28 16:41:30
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:41:30
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:41:31 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:41:31 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:41:31 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:41:31
Interactive Brokers | Disconnected. | 2019-04-28 16:41:31
Socket (1) | Closed. | 2019-04-28 16:41:31
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:42:01
Socket (1) | Creating socket. | 2019-04-28 16:42:01
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:42:01
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:42:02 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:42:02 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:42:02 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:42:02
Interactive Brokers | Disconnected. | 2019-04-28 16:42:02
Socket (1) | Closed. | 2019-04-28 16:42:02
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:42:32
Socket (1) | Creating socket. | 2019-04-28 16:42:32
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:42:32
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:42:33 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:42:33 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:42:33 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:42:33
Interactive Brokers | Disconnected. | 2019-04-28 16:42:33
Socket (1) | Closed. | 2019-04-28 16:42:33
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:43:03
Socket (1) | Creating socket. | 2019-04-28 16:43:03
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:43:03
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:43:04 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:43:04 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:43:04 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:43:04
Interactive Brokers | Disconnected. | 2019-04-28 16:43:04
Socket (1) | Closed. | 2019-04-28 16:43:04
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:43:34
Socket (1) | Creating socket. | 2019-04-28 16:43:34
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:43:34
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:43:35 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:43:35 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:43:35 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:43:35
Interactive Brokers | Disconnected. | 2019-04-28 16:43:35
Socket (1) | Closed. | 2019-04-28 16:43:35
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:44:05
Socket (1) | Creating socket. | 2019-04-28 16:44:05
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:44:05
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:44:06 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:44:06 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:44:06 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:44:06
Interactive Brokers | Disconnected. | 2019-04-28 16:44:06
Socket (1) | Closed. | 2019-04-28 16:44:06
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:44:36
Socket (1) | Creating socket. | 2019-04-28 16:44:36
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:44:36
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:44:37 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:44:37 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:44:37 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:44:37
Interactive Brokers | Disconnected. | 2019-04-28 16:44:37
Socket (1) | Closed. | 2019-04-28 16:44:37
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:45:07
Socket (1) | Creating socket. | 2019-04-28 16:45:07
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:45:07
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:45:08 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:45:08 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:45:08 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:45:08
Interactive Brokers | Disconnected. | 2019-04-28 16:45:08
Socket (1) | Closed. | 2019-04-28 16:45:08
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:45:38
Socket (1) | Creating socket. | 2019-04-28 16:45:38
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:45:38
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:45:39 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:45:39 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:45:39 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:45:39
Interactive Brokers | Disconnected. | 2019-04-28 16:45:39
Socket (1) | Closed. | 2019-04-28 16:45:39
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:46:09
Socket (1) | Creating socket. | 2019-04-28 16:46:09
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:46:09
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:46:10 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:46:10 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:46:10 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:46:10
Interactive Brokers | Disconnected. | 2019-04-28 16:46:10
Socket (1) | Closed. | 2019-04-28 16:46:10
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:46:40
Socket (1) | Creating socket. | 2019-04-28 16:46:40
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:46:40
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:46:41 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:46:41 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:46:41 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:46:41
Interactive Brokers | Disconnected. | 2019-04-28 16:46:41
Socket (1) | Closed. | 2019-04-28 16:46:41
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:47:11
Socket (1) | Creating socket. | 2019-04-28 16:47:11
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:47:11
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:47:12 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:47:12 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:47:12 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:47:12
Interactive Brokers | Disconnected. | 2019-04-28 16:47:12
Socket (1) | Closed. | 2019-04-28 16:47:12
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:47:42
Socket (1) | Creating socket. | 2019-04-28 16:47:42
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:47:42
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:47:43 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:47:43 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:47:43 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:47:43
Interactive Brokers | Disconnected. | 2019-04-28 16:47:43
Socket (1) | Closed. | 2019-04-28 16:47:43
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:48:13
Socket (1) | Creating socket. | 2019-04-28 16:48:13
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:48:13
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:48:14 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:48:14 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:48:14 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:48:14
Interactive Brokers | Disconnected. | 2019-04-28 16:48:14
Socket (1) | Closed. | 2019-04-28 16:48:14
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:48:44
Socket (1) | Creating socket. | 2019-04-28 16:48:44
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:48:44
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:48:45 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:48:45 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:48:45 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:48:45
Interactive Brokers | Disconnected. | 2019-04-28 16:48:45
Socket (1) | Closed. | 2019-04-28 16:48:45
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:49:15
Socket (1) | Creating socket. | 2019-04-28 16:49:15
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:49:15
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:49:16 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:49:16 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:49:16 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:49:16
Interactive Brokers | Disconnected. | 2019-04-28 16:49:16
Socket (1) | Closed. | 2019-04-28 16:49:16
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:49:46
Socket (1) | Creating socket. | 2019-04-28 16:49:46
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:49:46
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:49:47 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:49:47 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:49:47 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:49:47
Interactive Brokers | Disconnected. | 2019-04-28 16:49:47
Socket (1) | Closed. | 2019-04-28 16:49:47
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:50:17
Socket (1) | Creating socket. | 2019-04-28 16:50:17
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:50:17
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:50:18 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:50:18 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:50:18 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:50:18
Interactive Brokers | Disconnected. | 2019-04-28 16:50:18
Socket (1) | Closed. | 2019-04-28 16:50:18
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:50:48
Socket (1) | Creating socket. | 2019-04-28 16:50:48
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:50:48
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:50:49 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:50:49 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:50:49 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:50:49
Interactive Brokers | Disconnected. | 2019-04-28 16:50:49
Socket (1) | Closed. | 2019-04-28 16:50:49
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:51:19
Socket (1) | Creating socket. | 2019-04-28 16:51:19
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:51:19
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:51:20 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:51:20 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:51:20 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:51:20
Interactive Brokers | Disconnected. | 2019-04-28 16:51:20
Socket (1) | Closed. | 2019-04-28 16:51:20
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:51:50
Socket (1) | Creating socket. | 2019-04-28 16:51:50
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:51:50
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:51:51 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:51:51 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:51:51 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:51:51
Interactive Brokers | Disconnected. | 2019-04-28 16:51:51
Socket (1) | Closed. | 2019-04-28 16:51:51
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:52:21
Socket (1) | Creating socket. | 2019-04-28 16:52:21
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:52:21
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:52:22 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:52:22 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:52:22 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:52:22
Interactive Brokers | Disconnected. | 2019-04-28 16:52:22
Socket (1) | Closed. | 2019-04-28 16:52:22
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:52:52
Socket (1) | Creating socket. | 2019-04-28 16:52:52
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:52:52
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:52:53 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:52:53 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:52:53 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:52:53
Interactive Brokers | Disconnected. | 2019-04-28 16:52:53
Socket (1) | Closed. | 2019-04-28 16:52:53
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:53:23
Socket (1) | Creating socket. | 2019-04-28 16:53:23
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:53:23
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:53:24 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:53:24 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:53:24 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:53:24
Interactive Brokers | Disconnected. | 2019-04-28 16:53:24
Socket (1) | Closed. | 2019-04-28 16:53:24
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:53:54
Socket (1) | Creating socket. | 2019-04-28 16:53:54
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:53:54
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:53:55 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:53:55 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:53:55 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:53:55
Interactive Brokers | Disconnected. | 2019-04-28 16:53:55
Socket (1) | Closed. | 2019-04-28 16:53:55
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:54:25
Socket (1) | Creating socket. | 2019-04-28 16:54:25
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:54:25
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:54:26 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:54:26 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:54:26 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:54:26
Interactive Brokers | Disconnected. | 2019-04-28 16:54:26
Socket (1) | Closed. | 2019-04-28 16:54:26
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:54:56
Socket (1) | Creating socket. | 2019-04-28 16:54:56
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:54:56
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:54:57 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:54:57 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:54:57 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:54:57
Interactive Brokers | Disconnected. | 2019-04-28 16:54:57
Socket (1) | Closed. | 2019-04-28 16:54:57
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:55:27
Socket (1) | Creating socket. | 2019-04-28 16:55:27
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:55:27
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:55:28 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:55:28 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:55:28 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:55:28
Interactive Brokers | Disconnected. | 2019-04-28 16:55:28
Socket (1) | Closed. | 2019-04-28 16:55:28
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:55:58
Socket (1) | Creating socket. | 2019-04-28 16:55:58
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:55:58
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:55:59 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:55:59 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:55:59 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:55:59
Interactive Brokers | Disconnected. | 2019-04-28 16:55:59
Socket (1) | Closed. | 2019-04-28 16:55:59
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:56:29
Socket (1) | Creating socket. | 2019-04-28 16:56:29
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:56:29
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:56:30 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:56:30 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:56:30 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:56:30
Interactive Brokers | Disconnected. | 2019-04-28 16:56:30
Socket (1) | Closed. | 2019-04-28 16:56:30
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:57:00
Socket (1) | Creating socket. | 2019-04-28 16:57:00
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:57:00
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:57:01 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:57:01 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:57:01 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:57:01
Interactive Brokers | Disconnected. | 2019-04-28 16:57:01
Socket (1) | Closed. | 2019-04-28 16:57:01
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:57:31
Socket (1) | Creating socket. | 2019-04-28 16:57:31
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:57:31
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:57:32 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:57:32 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:57:32 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:57:32
Interactive Brokers | Disconnected. | 2019-04-28 16:57:32
Socket (1) | Closed. | 2019-04-28 16:57:32
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:58:02
Socket (1) | Creating socket. | 2019-04-28 16:58:02
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:58:02
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:58:03 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:58:03 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:58:03 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:58:03
Interactive Brokers | Disconnected. | 2019-04-28 16:58:03
Socket (1) | Closed. | 2019-04-28 16:58:03
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:58:33
Socket (1) | Creating socket. | 2019-04-28 16:58:33
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:58:33
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:58:34 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:58:34 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:58:34 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:58:34
Interactive Brokers | Disconnected. | 2019-04-28 16:58:34
Socket (1) | Closed. | 2019-04-28 16:58:34
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:59:04
Socket (1) | Creating socket. | 2019-04-28 16:59:04
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:59:04
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:59:05 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:59:05 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:59:05 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:59:05
Interactive Brokers | Disconnected. | 2019-04-28 16:59:05
Socket (1) | Closed. | 2019-04-28 16:59:05
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 16:59:35
Socket (1) | Creating socket. | 2019-04-28 16:59:35
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 16:59:35
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 16:59:36 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 16:59:36 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 16:59:36 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 16:59:36
Interactive Brokers | Disconnected. | 2019-04-28 16:59:36
Socket (1) | Closed. | 2019-04-28 16:59:36
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:00:06
Socket (1) | Creating socket. | 2019-04-28 17:00:06
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:00:06
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:00:07 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:00:07 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:00:07 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:00:07
Interactive Brokers | Disconnected. | 2019-04-28 17:00:07
Socket (1) | Closed. | 2019-04-28 17:00:07
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:00:37
Socket (1) | Creating socket. | 2019-04-28 17:00:37
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:00:37
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:00:38 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:00:38 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:00:38 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:00:38
Interactive Brokers | Disconnected. | 2019-04-28 17:00:38
Socket (1) | Closed. | 2019-04-28 17:00:38
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:01:08
Socket (1) | Creating socket. | 2019-04-28 17:01:08
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:01:08
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:01:09 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:01:09 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:01:09 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:01:09
Interactive Brokers | Disconnected. | 2019-04-28 17:01:09
Socket (1) | Closed. | 2019-04-28 17:01:09
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:01:39
Socket (1) | Creating socket. | 2019-04-28 17:01:39
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:01:39
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:01:40 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:01:40 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:01:40 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:01:40
Interactive Brokers | Disconnected. | 2019-04-28 17:01:40
Socket (1) | Closed. | 2019-04-28 17:01:40
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:02:10
Socket (1) | Creating socket. | 2019-04-28 17:02:10
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:02:10
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:02:11 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:02:11 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:02:11 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:02:11
Interactive Brokers | Disconnected. | 2019-04-28 17:02:11
Socket (1) | Closed. | 2019-04-28 17:02:11
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:02:41
Socket (1) | Creating socket. | 2019-04-28 17:02:41
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:02:41
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:02:42 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:02:42 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:02:42 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:02:42
Interactive Brokers | Disconnected. | 2019-04-28 17:02:42
Socket (1) | Closed. | 2019-04-28 17:02:42
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:03:12
Socket (2) | Creating socket. | 2019-04-28 17:03:12
Socket (2) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:03:12
Socket (2) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:03:13 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:03:13 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:03:13 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:03:13
Interactive Brokers | Disconnected. | 2019-04-28 17:03:13
Socket (2) | Closed. | 2019-04-28 17:03:13
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:03:43
Socket (1) | Creating socket. | 2019-04-28 17:03:43
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:03:43
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:03:44 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:03:44 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:03:44 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:03:44
Interactive Brokers | Disconnected. | 2019-04-28 17:03:44
Socket (1) | Closed. | 2019-04-28 17:03:44
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:04:14
Socket (1) | Creating socket. | 2019-04-28 17:04:14
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:04:14
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:04:15 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:04:15 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:04:15 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:04:15
Interactive Brokers | Disconnected. | 2019-04-28 17:04:15
Socket (1) | Closed. | 2019-04-28 17:04:15
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:04:45
Socket (1) | Creating socket. | 2019-04-28 17:04:45
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:04:45
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:04:46 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:04:46 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:04:46 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:04:46
Interactive Brokers | Disconnected. | 2019-04-28 17:04:46
Socket (1) | Closed. | 2019-04-28 17:04:46
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:05:16
Socket (1) | Creating socket. | 2019-04-28 17:05:16
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:05:16
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:05:17 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:05:17 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:05:17 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:05:17
Interactive Brokers | Disconnected. | 2019-04-28 17:05:17
Socket (1) | Closed. | 2019-04-28 17:05:17
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:05:47
Socket (1) | Creating socket. | 2019-04-28 17:05:47
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:05:47
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:05:48 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:05:48 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:05:48 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:05:48
Interactive Brokers | Disconnected. | 2019-04-28 17:05:48
Socket (1) | Closed. | 2019-04-28 17:05:48
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:06:18
Socket (1) | Creating socket. | 2019-04-28 17:06:18
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:06:18
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:06:19 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:06:19 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:06:19 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:06:19
Interactive Brokers | Disconnected. | 2019-04-28 17:06:19
Socket (1) | Closed. | 2019-04-28 17:06:19
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:06:49
Socket (1) | Creating socket. | 2019-04-28 17:06:49
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:06:49
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:06:50 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:06:50 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:06:50 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:06:50
Interactive Brokers | Disconnected. | 2019-04-28 17:06:50
Socket (1) | Closed. | 2019-04-28 17:06:50
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:07:20
Socket (1) | Creating socket. | 2019-04-28 17:07:20
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:07:20
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:07:21 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:07:21 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:07:21 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:07:21
Interactive Brokers | Disconnected. | 2019-04-28 17:07:21
Socket (1) | Closed. | 2019-04-28 17:07:21
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:07:51
Socket (1) | Creating socket. | 2019-04-28 17:07:51
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:07:51
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:07:52 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:07:52 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:07:52 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:07:52
Interactive Brokers | Disconnected. | 2019-04-28 17:07:52
Socket (1) | Closed. | 2019-04-28 17:07:52
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:08:22
Socket (1) | Creating socket. | 2019-04-28 17:08:22
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:08:22
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:08:23 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:08:23 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:08:23 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:08:23
Interactive Brokers | Disconnected. | 2019-04-28 17:08:23
Socket (1) | Closed. | 2019-04-28 17:08:23
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:08:53
Socket (1) | Creating socket. | 2019-04-28 17:08:53
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:08:53
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:08:54 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:08:54 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:08:54 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:08:54
Interactive Brokers | Disconnected. | 2019-04-28 17:08:54
Socket (1) | Closed. | 2019-04-28 17:08:54
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:09:24
Socket (1) | Creating socket. | 2019-04-28 17:09:24
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:09:24
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:09:25 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:09:25 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:09:25 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:09:25
Interactive Brokers | Disconnected. | 2019-04-28 17:09:25
Socket (1) | Closed. | 2019-04-28 17:09:25
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:09:55
Socket (1) | Creating socket. | 2019-04-28 17:09:55
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:09:55
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:09:56 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:09:56 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:09:56 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:09:56
Interactive Brokers | Disconnected. | 2019-04-28 17:09:56
Socket (1) | Closed. | 2019-04-28 17:09:56
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:10:26
Socket (1) | Creating socket. | 2019-04-28 17:10:26
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:10:26
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:10:27 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:10:27 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:10:27 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:10:27
Interactive Brokers | Disconnected. | 2019-04-28 17:10:27
Socket (1) | Closed. | 2019-04-28 17:10:27
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:10:57
Socket (1) | Creating socket. | 2019-04-28 17:10:57
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:10:57
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:10:58 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:10:58 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:10:58 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:10:58
Interactive Brokers | Disconnected. | 2019-04-28 17:10:58
Socket (1) | Closed. | 2019-04-28 17:10:58
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:11:28
Socket (1) | Creating socket. | 2019-04-28 17:11:28
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:11:28
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:11:29 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:11:29 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:11:29 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:11:29
Interactive Brokers | Disconnected. | 2019-04-28 17:11:29
Socket (1) | Closed. | 2019-04-28 17:11:29
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:11:59
Socket (1) | Creating socket. | 2019-04-28 17:11:59
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:11:59
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:12:00 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:12:00 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:12:00 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:12:00
Interactive Brokers | Disconnected. | 2019-04-28 17:12:00
Socket (1) | Closed. | 2019-04-28 17:12:00
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:12:30
Socket (1) | Creating socket. | 2019-04-28 17:12:30
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:12:30
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:12:31 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:12:31 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:12:31 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:12:31
Interactive Brokers | Disconnected. | 2019-04-28 17:12:31
Socket (1) | Closed. | 2019-04-28 17:12:31
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:13:01
Socket (1) | Creating socket. | 2019-04-28 17:13:01
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:13:01
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:13:02 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:13:02 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:13:02 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:13:02
Interactive Brokers | Disconnected. | 2019-04-28 17:13:02
Socket (1) | Closed. | 2019-04-28 17:13:02
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:13:32
Socket (1) | Creating socket. | 2019-04-28 17:13:32
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:13:32
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:13:33 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:13:33 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:13:33 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:13:33
Interactive Brokers | Disconnected. | 2019-04-28 17:13:33
Socket (1) | Closed. | 2019-04-28 17:13:33
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:14:03
Socket (1) | Creating socket. | 2019-04-28 17:14:03
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:14:03
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:14:04 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:14:04 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:14:04 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:14:04
Interactive Brokers | Disconnected. | 2019-04-28 17:14:04
Socket (1) | Closed. | 2019-04-28 17:14:04
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:14:34
Socket (1) | Creating socket. | 2019-04-28 17:14:34
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:14:34
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:14:35 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:14:35 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:14:35 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:14:35
Interactive Brokers | Disconnected. | 2019-04-28 17:14:35
Socket (1) | Closed. | 2019-04-28 17:14:35
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:15:05
Socket (1) | Creating socket. | 2019-04-28 17:15:05
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:15:05
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:15:06 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:15:06 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:15:06 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:15:06
Interactive Brokers | Disconnected. | 2019-04-28 17:15:06
Socket (1) | Closed. | 2019-04-28 17:15:06
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:15:36
Socket (1) | Creating socket. | 2019-04-28 17:15:36
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:15:36
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:15:37 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:15:37 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:15:37 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:15:37
Interactive Brokers | Disconnected. | 2019-04-28 17:15:37
Socket (1) | Closed. | 2019-04-28 17:15:37
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:16:07
Socket (1) | Creating socket. | 2019-04-28 17:16:07
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:16:07
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:16:08 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:16:08 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:16:08 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:16:08
Interactive Brokers | Disconnected. | 2019-04-28 17:16:08
Socket (1) | Closed. | 2019-04-28 17:16:08
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:16:38
Socket (1) | Creating socket. | 2019-04-28 17:16:38
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:16:38
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:16:39 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:16:39 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:16:39 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:16:39
Interactive Brokers | Disconnected. | 2019-04-28 17:16:39
Socket (1) | Closed. | 2019-04-28 17:16:39
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:17:09
Socket (1) | Creating socket. | 2019-04-28 17:17:09
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:17:09
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:17:10 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:17:10 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:17:10 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:17:10
Interactive Brokers | Disconnected. | 2019-04-28 17:17:10
Socket (1) | Closed. | 2019-04-28 17:17:10
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:17:41
Socket (1) | Creating socket. | 2019-04-28 17:17:41
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:17:41
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:17:42 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:17:42 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:17:42 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:17:42
Interactive Brokers | Disconnected. | 2019-04-28 17:17:42
Socket (1) | Closed. | 2019-04-28 17:17:42
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:18:12
Socket (2) | Creating socket. | 2019-04-28 17:18:12
Socket (2) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:18:12
Socket (2) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:18:13 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:18:13 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:18:13 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:18:13
Interactive Brokers | Disconnected. | 2019-04-28 17:18:13
Socket (2) | Closed. | 2019-04-28 17:18:13
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:18:43
Socket (1) | Creating socket. | 2019-04-28 17:18:43
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:18:43
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:18:44 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:18:44 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:18:44 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:18:44
Interactive Brokers | Disconnected. | 2019-04-28 17:18:44
Socket (1) | Closed. | 2019-04-28 17:18:44
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:19:14
Socket (1) | Creating socket. | 2019-04-28 17:19:14
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:19:14
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:19:15 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:19:15 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:19:15 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:19:15
Interactive Brokers | Disconnected. | 2019-04-28 17:19:15
Socket (1) | Closed. | 2019-04-28 17:19:15
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:19:45
Socket (1) | Creating socket. | 2019-04-28 17:19:45
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:19:45
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:19:46 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:19:46 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:19:46 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:19:46
Interactive Brokers | Disconnected. | 2019-04-28 17:19:46
Socket (1) | Closed. | 2019-04-28 17:19:46
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:20:16
Socket (1) | Creating socket. | 2019-04-28 17:20:16
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:20:16
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:20:17 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:20:17 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:20:17 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:20:17
Interactive Brokers | Disconnected. | 2019-04-28 17:20:17
Socket (1) | Closed. | 2019-04-28 17:20:17
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:20:47
Socket (1) | Creating socket. | 2019-04-28 17:20:47
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:20:47
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:20:48 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:20:48 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:20:48 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:20:48
Interactive Brokers | Disconnected. | 2019-04-28 17:20:48
Socket (1) | Closed. | 2019-04-28 17:20:48
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:21:18
Socket (1) | Creating socket. | 2019-04-28 17:21:18
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:21:18
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:21:19 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:21:19 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:21:19 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:21:19
Interactive Brokers | Disconnected. | 2019-04-28 17:21:19
Socket (1) | Closed. | 2019-04-28 17:21:19
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:21:49
Socket (1) | Creating socket. | 2019-04-28 17:21:49
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:21:49
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:21:50 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:21:50 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:21:50 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:21:50
Interactive Brokers | Disconnected. | 2019-04-28 17:21:50
Socket (1) | Closed. | 2019-04-28 17:21:50
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:22:20
Socket (1) | Creating socket. | 2019-04-28 17:22:20
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:22:20
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:22:21 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:22:21 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:22:21 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:22:21
Interactive Brokers | Disconnected. | 2019-04-28 17:22:21
Socket (1) | Closed. | 2019-04-28 17:22:21
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:22:51
Socket (1) | Creating socket. | 2019-04-28 17:22:51
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:22:51
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:22:52 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:22:52 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:22:52 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:22:52
Interactive Brokers | Disconnected. | 2019-04-28 17:22:52
Socket (1) | Closed. | 2019-04-28 17:22:52
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:23:22
Socket (1) | Creating socket. | 2019-04-28 17:23:22
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:23:22
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:23:23 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:23:23 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:23:23 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:23:23
Interactive Brokers | Disconnected. | 2019-04-28 17:23:23
Socket (1) | Closed. | 2019-04-28 17:23:23
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:23:53
Socket (1) | Creating socket. | 2019-04-28 17:23:53
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:23:53
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:23:54 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:23:54 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:23:54 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:23:54
Interactive Brokers | Disconnected. | 2019-04-28 17:23:54
Socket (1) | Closed. | 2019-04-28 17:23:54
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:24:24
Socket (1) | Creating socket. | 2019-04-28 17:24:24
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:24:24
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:24:25 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:24:25 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:24:25 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:24:25
Interactive Brokers | Disconnected. | 2019-04-28 17:24:25
Socket (1) | Closed. | 2019-04-28 17:24:25
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:24:55
Socket (1) | Creating socket. | 2019-04-28 17:24:55
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:24:55
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:24:56 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:24:56 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:24:56 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:24:56
Interactive Brokers | Disconnected. | 2019-04-28 17:24:56
Socket (1) | Closed. | 2019-04-28 17:24:56
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:25:26
Socket (1) | Creating socket. | 2019-04-28 17:25:26
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:25:26
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:25:27 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:25:27 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:25:27 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:25:27
Interactive Brokers | Disconnected. | 2019-04-28 17:25:27
Socket (1) | Closed. | 2019-04-28 17:25:27
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:25:57
Socket (1) | Creating socket. | 2019-04-28 17:25:57
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:25:57
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:25:58 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:25:58 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:25:58 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:25:58
Interactive Brokers | Disconnected. | 2019-04-28 17:25:58
Socket (1) | Closed. | 2019-04-28 17:25:58
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-28 17:26:28
Socket (1) | Creating socket. | 2019-04-28 17:26:28
Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-28 17:26:28
Socket (1) | Connect event error. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2019-04-28 17:26:29 *
Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-28 17:26:29 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-28 17:26:29 *
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:26:29
Interactive Brokers | Disconnected. | 2019-04-28 17:26:29
Socket (1) | Closed. | 2019-04-28 17:26:29
Interactive Brokers | Reconnect try count has been reached. Will no longer try to reconnect. | 2019-04-28 17:26:59
Interactive Brokers | Disconnected from the server. | 2019-04-28 17:26:59
SC Data - All Services | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-04-28 17:35:18
Intraday data recording state for symbol ESM19 is set to download 'Pending'. | 2019-04-28 17:35:18
HD Request # 3 | Downloading Intraday chart data for ESM19 to the file ESM19.scid. Service: cme | 2019-04-28 17:35:18
HD Request # 3 | Download start date-time: 2019-04-27 04:59:59.000 | 2019-04-28 17:35:18
HD Request # 3 | Using server: ds1.sierracharts.com port 10149 | 2019-04-28 17:35:18
Socket (1) | Creating socket. | 2019-04-28 17:35:18
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-04-28 17:35:18
HD Request # 3 | Setting DTC encoding to Binary VLS | 2019-04-28 17:35:18
HD Request # 3 | Sending historical data logon request message. | 2019-04-28 17:35:18
HD Request # 3 | Requesting Intraday data. Start date-time: 2019-04-27 04:59:59. Record interval: 0. Symbol: ESM19 | 2019-04-28 17:35:19
HD Request # 3 | Decompressing data. | 2019-04-28 17:35:19
HD Request # 3 | Receiving Intraday data for ESM19 starting at 2019-04-27 04:59:59 | 2019-04-28 17:35:19
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-04-28 17:35:19
Historical data download thread signaled to stop. | 2019-04-28 17:35:19
HD Request # 3 | Received 7 records from 2019-04-27 04:59:59 to 2019-04-27 04:59:59 (0.0 seconds) and wrote 0 records for ESM19 | 2019-04-28 17:35:19
HD Request # 3 | Completion time: 0s | 2019-04-28 17:35:19
HD Request # 3 | Intraday data download complete for ESM19. Unique request ID: 2 | 2019-04-28 17:35:19
Removed historical data download ID 2 | 2019-04-28 17:35:19
Real-time Intraday chart data file updates started for ESM19 | 2019-04-28 17:35:19
Intraday chart data file opened for ESM19 | 2019-04-28 17:35:19
Socket (1) | Socket gracefully closed by remote side. | 2019-04-28 17:35:19
Socket (1) | Closed. | 2019-04-28 17:35:19
[2019-04-29 21:41:07]
I have logged-in my Interactive Brokers account and change the service setting back to "SC Data - All Services [data]", in order to get the data feed discount for IB (eligible future broker) user.
The problem is we do not see a successful connection to the Interactive Brokers trader workstation. Follow through the step-by-step instructions here to get that successful connection to your live account:
Interactive Brokers Trading Service: Setup Instructions
You will then be able to receive the CME real-time data after changing back to SC Data-All Services.
Date Time Of Last Edit: 2019-04-29 21:41:39
