Date/Time: Fri, 31 Jan 2025 09:03:20 +0000
Time alert
View Count: 766
[2019-04-27 08:57:39] |
Dom7364 - Posts: 257 |
Hi, how do you get a Time alert, both visual and sound? For example at 16.00 I am looking to get a sound alert and visual alert (line, or message or else)? Thanks
[2019-04-27 09:46:48] |
Ackin - Posts: 1865 |
Try this: Time Line |
[2019-04-27 10:21:09] |
Thanks mate, been using this but not quite what I am looking to achieve altough it sort of works, except on a TPO it only works if ALL profiles are displayed in their own column as if done only on the current/last TPO the Time Line study does not display anything. Clearly an issue with it.
[2019-04-27 10:32:44] |
hmmm....so then you can modify the study countdown timer and compare it with the system time.
