Date/Time: Sun, 24 Nov 2024 16:32:27 +0000
TT Fix Disconnects
View Count: 1273
[2013-11-22 15:06:55] |
User37170 - Posts: 29 |
Happening a lot these days. Suggestions appreciated. |
SC 22 Nov 2013 Log File.txt - Attached On 2013-11-22 15:06:22 UTC - Size: 27.9 KB - 467 views |
[2013-11-22 15:18:41] |
This is the problem connection: Starting the Orders session. Connecting to 66.150.104.15 port 10501... | 2013-11-22 16:50:51 Refer to help topic 1.2 here: http://www.sierrachart.com/index.php?l=doc/helpdetails1.html And also contact your broker about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-22 16:20:54] |
batman_ - Posts: 190 |
SC Do i need clearing firm to activate sierra chart in order to submit order to TTFIX? or just key in TTFIX login into data connection will do. |
[2013-11-22 16:37:08] |
Do i need clearing firm to activate sierra chart in order to submit order to TTFIX? No.
