Date/Time: Mon, 03 Feb 2025 14:03:28 +0000
Keyboard shortcut to Invert Prices
View Count: 775
[2019-04-26 22:43:17] |
Stephan908 - Posts: 46 |
Hi, is there a way to create a keyboard shortcut for this setting: Chart Settings -> Advanced Settings 2 -> Invert Prices? If a keyboard shortcut is not possible, is there a way to do add it as a button to a control bar or a chart shortcut menu drop down? Thanks!
[2019-04-27 01:01:24] |
No, none of this is supported.
[2019-11-20 09:38:44] |
User34124 - Posts: 279 |
Save the study as a collection, then fiddle with adding it to a control bar, the hotkey that
