Date/Time: Fri, 31 Jan 2025 14:48:00 +0000
Trading options
View Count: 3574
[2019-04-26 18:07:48] |
User174262 - Posts: 13 |
Hello, actually i use the service package 5 from sierra chart. I would like also use options in my trading. Unfortunately i can not find this in sierra chart. I have no trading account with a broker. Please let me know which possibilities can i do in sierra chart tu use options. I would prefer future options (DAX, indices) maybe from EUREX. For your reply many thanks Best regards |
[2019-04-27 01:06:08] |
Futures options are well supported in Sierra Chart for the CME: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#FuturesOptions But the data is very costly without a trading account. And we are not sure where you can get EUREX options data from. That is not supported in Sierra Chart and CQG does not have it either in our experience. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-27 01:06:14
[2019-05-15 19:59:38] |
Sierra Chart - Max - Posts: 5780 |
From User: Hello, many thanks for your reply. Yesterday I had write a mail to Eurex about data to get for option trading. Eurex said Sierra Chart need a direct connection to the Eurex server to use the options data from Eurex. With that it is possilbe to get the options data from eurex. I and other users would be very pleased to be able to use this function in sierra chart. If you want i can tell you the direct contact from eurex to manage this subject. I would glad to hear from you a positive reply. Best regards Sierra Chart Support |
[2019-05-16 04:22:57] |
Yes eventually EUREX options support in Sierra Chart will come. Update: We are not sure about that due restrictions and difficulties by EUREX and difficulties with them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-05 08:57:10
