Date/Time: Fri, 31 Jan 2025 09:10:16 +0000
[Locked] - Chart Link colors not showing in version 1910
View Count: 1076
[2019-04-26 03:59:08] |
User62936 - Posts: 68 |
Back in version 1890, it was working fine as per first image. You see how my ES and NQ charts are linked via different colors. In version 1910 now, the colors are not showing, although the linking does still work which I set to scroll position. Its the same chartbook so no setting has been changed when upgrading.
Private File Private File |
[2019-04-26 06:47:42] |
ILIM KIRGIZ - Posts: 187 |
Yes, they are not. Also, double clicking to chart tab does not maximize it as It was used to be. I needed to roll back to 1898. Date Time Of Last Edit: 2019-04-26 06:48:21
[2019-04-26 14:13:43] |
All of this is now supported in prerelease 1912: New Tab Control for Main Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-27 07:06:13] |
I have installed version 1912 and I am still not getting colors for the linked charts.
[2019-04-27 20:34:48] |
I also do not get colors and I can't move tabs as well with 1912.
[2019-04-27 23:15:15] |
We will check on the link colors. We are not seeing any issue with moving tabs. Could you describe whether you are moving the child window tabs or the Chartbook tabs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-28 06:12:00] |
nicktrader - Posts: 733 |
I also do not get colors. I am using LINK #3 and 10 as you can see in the attached pic
[2019-04-28 06:49:42] |
Yes, we are aware of this. We will get this resolved Monday.
[2019-04-28 11:40:41] |
Reply to #6: I can not move MDI window tabs as I was used to.
Date Time Of Last Edit: 2019-04-29 07:52:22
[2019-04-29 23:19:24] |
We are not able to reproduce any problems with this. Test again on the latest version which is now 1913 and let us know if you still see a problem.
[2019-04-30 03:46:41] |
Tabs with colors works now. Txs
colored tabs.png / V - Attached On 2019-04-30 03:46:29 UTC - Size: 22.03 KB - 291 views |
[2019-04-30 03:57:24] |
You do not need to post anything.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-30 03:58:01
