Date/Time: Mon, 21 Sep 2026 12:30:44 +0000
Daily Volume problem with CME Data Feed
View Count: 1678
| [2013-11-22 14:33:37] |
| TI Anon - Posts: 36 |
Daily Volume using the CME Data Feed is not correct. It does seem to catch up eventually but not when starting charts. See attached comparison.
| [2013-11-22 18:32:43] |
This will be resolved with a software update this evening.
