Date/Time: Fri, 31 Jan 2025 08:45:52 +0000
Saving Draw Volume Profile Configurations
View Count: 2230
[2019-04-25 14:33:00]
pa_trader - Posts: 29
Is there a way to save multiple Draw Volume Profile configs, like it is possible for other Tools ? If I open a "Tool Configs" window I am able to save TC1, TC2 etc and they show up as possible configs when I right click on a Volume Profile but those TC1/2/3 etc dont load up when I select them.
Is this happening because Volume Profiles are loaded as a study and not really a "Drawing Tool", per se ?
Also, has there been any development work to highlight POC/ValArea on not just based on the Total Volume of the profile but separately on BidVol or AskVol ?
Thanks much !
[2019-04-25 18:10:41]
John - SC Support - Posts: 37621
Refer to the following for how to create/save Draw Volume Profile configurations:
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
However, for this functionality you must be running a recent version of Sierra Chart. We see you are running some older versions.
There has not been any work on having the highlights based on items other than the Total Volume. It is something we have on our list to do, but we cannot give any idea of when we may get to this work.
Date Time Of Last Edit: 2019-04-25 18:43:48
