Date/Time: Fri, 31 Jan 2025 08:47:35 +0000
Support Left Click to Select Chart Drawings not functioning
View Count: 583
[2019-04-25 12:53:19] |
ARDAN - Posts: 66 |
I enabled Support Left Click to Select Chart Drawings and Double Click on Drawing Brings Up Drawing Properties options. When the Pointer tool is selected, when I left click over a drawing It is not selected. When I double click on the drawing Properties Window does not show up. My settings are attached. How can I resolve this issue? |
settings.PNG / V - Attached On 2019-04-25 12:53:08 UTC - Size: 90.28 KB - 235 views |
[2019-04-25 18:37:24] |
Upgrade to the latest release. There was a problem with these functions a little while ago that was fixed. It sounds like you may be on one of those versions. Refer to the following to perform a Fast Update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
