Date/Time: Fri, 31 Jan 2025 08:50:31 +0000
Fonts
View Count: 574
[2019-04-24 17:17:42] |
Dennis B. - Posts: 286 |
Can you change the fonts on just the chartbook tabs ?
[2019-04-24 17:56:21] |
There is just one font setting for the tabs. To change the font, refer to: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-24 17:57:04
