Date/Time: Sat, 12 Sep 2026 09:16:46 +0000
re: new CME data support...
View Count: 1552
| [2013-11-22 07:16:48] |
| User53765 - Posts: 66 |
Hi Sierra Support, A question of interest please. When do you expect to be able to use Sierra chart on a stand alone feed with the new CME direct data feed without the necessity of having an account with a supported broker? An approximate timeline would be great. Thanks in advance. |
| [2013-11-22 18:37:54] |
Our expectation is to get this out before the end of the year or very early in January.
