Date/Time: Thu, 26 Sep 2024 23:33:08 +0000
how to use both sierra chart and interactive brokers data at same time?
View Count: 1300
[2013-11-22 07:06:53] |
enemyspy - Posts: 306 |
So I am connected to the SC real time futures feed which is great. However I have come into a situation where I need the interactive brokers data to populate a DOM instead of the SC feed. This need arises when I am trading the EURO as I get my chart data from the regular symbol EUR, but trade the M6E for better scaling strategies with risk control . The M6E does not populate the DOM correctly unless I using the IB data feed.
[2013-11-22 09:05:23] |
so to clarify this question better. Can I use the IB data for just one symbol while maintaining Use of the The SC CME futures data for other symbols simultaneously?
[2013-11-22 17:32:21] |
The Depth of market data problems with the M6E will be resolved by the end of the day today. Also please update to version 1050. For future reference, to do what you want would require you to install another copy of Sierra Chart that has the Allow Support For Sierra Chart Data Feed option disabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-22 17:33:05
