Date/Time: Fri, 31 Jan 2025 09:13:17 +0000
new computer and I cannot find a scrollbar
View Count: 1243
[2019-04-23 19:59:27] |
sjk - Posts: 43 |
help
[2019-04-23 21:24:30] |
We see each chart has a scrollbar. Are you referring to the scrollbar for the main Sierra Chart window containing the charts? If so, refer to: General Settings Window: Enable Workspace Scrolling (Global Settings >> General Settings >> GUI >> Scroll) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-24 00:12:06] |
sjk - Posts: 43 |
I searched under "scrollbar" and got nothing. So Chartbooks are also called Workspaces? sk |
[2019-04-25 07:48:47] |
No, the Workspace is the area that contains the charts in the main Sierra Chart program. You have your Charts tiled in the Workspace so you can see multiple charts at the same time, but some of the charts are not fully visible since they are off the bottom of the Workspace. Each of your charts has the scroll bar displayed at the bottom of the chart, so we assumed that you were referencing the ability to have a scrollbar in the Workspace that would allow you to scroll the Workspace to be able to see those charts that are outside of the view. After you select the option for Enable Workspace Scrolling you need to restart Sierra Chart to see the new scrollbars that will show up on the side of the Workspace. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
