Date/Time: Fri, 31 Jan 2025 08:52:40 +0000
Reported bugs in the new release.
View Count: 1008
[2019-04-23 05:23:08]
2garin - Posts: 184
I propose to launch a special thread for the detected errors.
release 1908.
window has stopped working:
Date Time Of Last Edit: 2019-04-24 04:36:15
image12.jpg / V - Attached On 2019-04-23 05:20:19 UTC - Size: 138.36 KB - 304 views
[2019-04-23 05:26:09]
2garin - Posts: 184
double tap stopped working (maximize window)
image13.jpg / V - Attached On 2019-04-23 05:25:36 UTC - Size: 14.32 KB - 298 views
[2019-04-23 06:38:35]
Attach the Chartbook you are using and we will test it. Here are instructions to do that:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2019-04-23 06:51:20]
We are looking into the issue now.
[2019-04-23 07:04:23]
We did find one problem and we are resolving it now. We will resolve all issues. Just allow about an hour for a new release.
Date Time Of Last Edit: 2019-04-23 07:04:33
[2019-04-23 10:13:32]
We have released version 1910. Update and let us know if you see any further problems. Here are the instructions:
We do apologize for the issue.
[2019-04-23 13:12:06]
User184582 - Posts: 14
hi ,
with the 1908 version
I realize that there is no longer the cursor that allows to move the tabs of the different charts, in charbook at the bottom.
thanks
[2019-04-23 18:23:30]
We are still working on this and expect it will be ready next week.
[2019-04-28 21:38:02]
2garin - Posts: 184
version 1912
image1912.jpg / V - Attached On 2019-04-28 21:36:49 UTC - Size: 174.33 KB - 283 views
image1912_1.jpg / V - Attached On 2019-04-28 21:36:56 UTC - Size: 138.44 KB - 265 views
[2019-04-28 22:58:10]
We are aware of the tab coloring limitation and we are still working on that.
However, there is no problem with the Chart Values Window. Nothing has even changed with that. What is the problem you are having with the Chart Values window?
[2019-04-28 23:17:54]
2garin - Posts: 184
moving crosshairs does not change the values in the window.
After installing the terminal, I copy the specified files into the program folder. The problem can hide in this?
Date Time Of Last Edit: 2019-04-28 23:23:48
image1912_2.jpg / V - Attached On 2019-04-28 23:23:43 UTC - Size: 20.59 KB - 292 views
[2019-04-29 06:34:24]
You need to use Window >> Tool Values Window.
