Date/Time: Fri, 31 Jan 2025 06:17:33 +0000
TransAct Futures Sierra Chart
View Count: 1378
[2019-04-23 01:00:40]
User103219 - Posts: 8
How can I get TA to launch the 64 bit version of SC rather than the 32 bit?
If I try to launch the 64 bit from my SC folder would be uname and password be the same as logging into TA?
Thank you in advance.
[2019-04-23 10:02:36]
You need to enable this option:
https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlwaysRun64BitVersion
[2019-04-23 10:32:47]
Thank you!
