Date/Time: Thu, 06 Feb 2025 22:59:44 +0000
ACSIL - General Settings, General 1, Chart Update Interval in ms
View Count: 1083
[2019-04-22 23:58:15] |
Kiwi - Posts: 375 |
I note that you have created a read only int variable sc.ChartUpdateIntervalInMilliseconds Would you please make it writable when you have a little time? Motivation: background charts can be set to longer times & the CUIIM can be used to change the trading charts from (say) 1000ms to 100ms for the active period. This keeps Sierra Chart's utilization low while stalking trades and makes it easy to switch to high / ultra-responsive while trading. |
[2020-05-14 17:27:06] |
jesslinn - Posts: 108 |
It would be great if the update interval were writable. Other motivation: When calculating a study for display purposes there is no need to call the study frequently. A study may know that it only needs to be called every 5 seconds or so. Thanks |
