Date/Time: Thu, 26 Sep 2024 23:30:01 +0000
[User Discussion] - Study/Price Overlay format request
View Count: 1504
[2013-11-22 01:08:45] |
FFTrader - Posts: 180 |
Hi, When I use the Study/Price Overlay study and choose to use Price, I have no control on the format of price bar. Is it possible so I can have this study plot the various different formats available to a normal study? e.g.: line, dash, arrow, square, point, etc. |
[2013-11-22 21:01:13] |
This is not supported or planned.
[2013-11-22 21:26:49] |
Sawtooth - Posts: 4092 |
You can use instance(s) of the Moving Average - Simple study, set the Based On to the Study/Price Overlay study, choose the Chart Region, choose the Input Data, set the Length to 1, choose the Draw Style. Then Hide the Study/Price Overlay study. |
[2013-11-23 03:55:47] |
Thank you tomglib. I managed to use Previous Bar - OHLC and then overlay that study. |
