Date/Time: Fri, 31 Jan 2025 06:05:01 +0000
Unable to download the Sierra program
View Count: 681
[2019-04-22 15:45:16]
User574910 - Posts: 1
Hello, I'm receiving the following error message while trying to download sierra on my new computer.
"error saving downloaded files to local system stopping installation" Can you please assist? Thank you
[2019-04-22 18:55:05]
In this particular case we recommend using the zip installer:
https://www.sierrachart.com/index.php?page=doc/SCZipInstallerList.php
Use version 1908.
Just extract the files into the folder you want to install Sierra Chart to which should be C:\SierraChart.
