Date/Time: Fri, 31 Jan 2025 06:20:31 +0000
price on range chart
View Count: 825
[2019-04-21 19:52:49]
User531621 - Posts: 103
Hi folks, on my range chart the price action is 4 points apart, ie: 2908.00 / 2910.00. i need the gap to be much smaller so that it shows .25,.50,.75 on all prices. ie: 2912.00 / 2912.25 / 2912.50 / 2912.75, etc, and without expanding the chart.
possible?
imageS&P 4 TICK SC F.US.EPM19 2.50 Range #8 _ E-Mini S&P 500_ .png / V - Attached On 2019-04-21 19:49:39 UTC - Size: 92.41 KB - 245 views
[2019-04-22 19:15:46]
You need to adjust the Scale Increment setting to what you require:
Chart Scale and Scale Adjusting: Scale Increment (Scale Settings)
And refer to:
Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph
[2019-04-22 23:00:16]
I managed to bring it down to a point spread , but still need a little help getting the .25,.50,.75 price action. I cant seem to find it in the links you sent. Please advise, thank you
[2019-04-23 10:16:35]
What did you set the Scale Increment setting to?
Date Time Of Last Edit: 2019-04-23 10:16:43
