Date/Time: Fri, 31 Jan 2025 05:56:28 +0000
Market Data Feed
View Count: 722
[2019-04-20 12:37:06]
User94606 - Posts: 327
Where can I change my market data provider? I went to file -> Data/Trade Service Settings but I am not seeing where you can specify a different data provider
[2019-04-20 23:52:24]
Yes that is where it is controlled. We also see you are using the Sierra Chart Exchange Data Feed which integrates with multiple supported Trading services.
What specifically did you want to use?
[2019-04-21 00:00:04]
I am would like to try out CQG and Rithmic as data providers. Where do I change the settings? I still need to continue to use Interactive Brokers
[2019-04-22 02:08:16]
In this case just install another copy of Sierra Chart:
Using Multiple Data and Trading Services at the Same Time
And follow the appropriate set up instructions for these services from this page:
Supported Data and Trading Services
Also be aware of this new service:
Sierra Chart / Trading Technologies Futures Order Routing Service
